I replaced my main and pilot jets because i was having issues with my carbs. I have a 1979 XS1100 Special with 78 carbs on it.
I put in new 147.5 main jets and 45 pilots and synced the carbs, it runs good at idle and when i twist the throttle quick, it no longer stutters or backfires out the intake. However, it does seem a little slow.
So i took it out on a quick spin and it doesn't have much for power. It is extremely slow when going 55 in 5th gear and trying to accelerate. Could this be a float height problem?
It barely speeds up at all when trying to accelerate at low rpms, the more throttle you give it, slow slower it goes.
I don't know much about it my guess it either the jets are still off, or the floats aren't right.
Any help is greatly appreciated, thanks
Edit: The bike has pod filters and 4 to 1 kerker exhaust and i uses the formula to figure out what jets i should use for a starting point. In case anyone is wondering. Thanks
