Carb Intake Boot Torque Settings Help!!@!!
  • lasvegas
    • Jan 2004
    • 2
    • las vegas
    my 1980 xs1100sg back fires a little allso
    i just took gas tank to shop have it boiled out it was reeeely rusty inside
    allso in process of cleaning carbs ive opted to leave the screws alone since dont have a tuneing device yet so i removed float bowls cleaned all the jets i was able to remove,
    major problem ive had is that the #3 #4 cylender EXHAUSTS seem to having lean condition causeing them to glow like toaster oven coil while #1 and #2 side remains nominal
    i havent started the thing since i notice the problem i allso removed ALLOT of the rush from the carb bowls,
    and im going to replace the intake boots the ones that run from the engine to the carb
    NOT the air filter boots,hope this well help fix problem with one side engine getting to hot or exhausting too hot for my likeing
    so now im at a stopping point, HOW MUCH TORQUE DO I PUT ON THE ALLEN BOLTS WHEN I INSTALL THE NEW INTAKES ITS NOT IN THE CLYMER MANUAL ANY WERE,
    part#'s for the intake boots
    2H7-13596-00 TWO PARTS
    2H7-13586-00 TWO PARTS
    APPRECIATE A RESPONSE thanks
    Tim
  • mitch
    • Oct 2002
    • 934
    Carbs
    Dont put those carbs back on . From what i read you didnt take the top off and pull the vacume slides out , then you need to remove the emulsifaction tubes. If there was rust in the tank those need to come out , You take the jet in the bottom middle out and push or lightly tap the tubes up towards the top of the carbs. Careful putting them back in,hope line up the spline so they will slide in right.I think about 6 ft lbs would do on the manifold hth .........MITCH
    Doug Mitchell
    82 XJ1100 sold
    2007 Stratoliner 1900 sold
    • Geezer
      • May 2003
      • 2985
      • Willamina, Oregon 97229
      Re: Carb Intake Boot Torque Settings Help!!@!!
      Tim
      7 foot pounds.
      Geezer
      • lasvegas
        • Jan 2004
        • 2
        • las vegas
        carb parts complete list ?
        i see no mentioning of a emulsification tube in this exploded view of the carbuerators or vacume slide??
        any one else have clyer manual xs1100 4ours 1978-1981
        #M411
        the exploded view is on page 147 chapter 6
        and it shows 60 diff individual parts
          The tube is item # 17. It's called the main screw. Clymer manual. chapt 6 p 147 fig 12. Also see pg 149 pic # 23 Called main nozzle
          • mitch
            • Oct 2002
            • 934
            OR try this
            Go to the forum front page
            scroll down to the maintenance section
            click on carbouraters
            click on Blaines XS11 carb FAQs
            I think this might help you a lot as it shows a pic of the tube in Question ...MITCH
            Doug Mitchell
            82 XJ1100 sold
