What would cause this???
  • tinman905
    • Aug 2007
    • 946
    • Orangeville,Ontario ,Canada
    I am helping MaximPhil repair his second gear on "Addie" and I found this all I can say is Phil is lucky we went in to repair his second gear. I think Phil will be needing another gear Phil should be online soon adding his comments
    As you can see there is a crack straight across the gear
    BDF Special
    Someone probably installed the clutch basket improperly and tightened it down without meshing the teeth on the two gears.
      "Hey, this clutch basket won't go on all the way?"
      "Slide it back and shove it forward REALLY hard! If that doesn't work, just hit it with that dead-blow hammer until it goes!"
      • tinman905
        • Aug 2007
        • 946
        I realized that after I posted. I am surprised the gear didn't come apart by now. Glad we caught when we did, it almost went back together like this.I think better lights in the garage will be needed too.
        BDF Special
        • tinman905
          • Aug 2007
          • 946
          Looks like a 3lb sledge was used.
          BDF Special
          • Elevener
            • 608
            • small town in TEXAS
            Better lights or less imbibing?
            Trapped in time. Surrounded by evil. Low on gas.
            1980 XS1100G 1179 kit, Tkat brace, progressive springs & shocks, jardine spaghetti, Mikes coils, Geezer's rectifier
            • tinman905
              • Aug 2007
              • 946
              [QUOTE=Elevener;367216]Better lights or less imbibing?
              Better lights of course ,there's nothing wrong with the beer
              BDF Special
                Hmmmmm.... Noticing the metal lathe in the back. I don't know what I'd do with one, but I sure would like to have one! lol.
                • Joab
                  • Aug 2010
                  • 472
                  • Ozark, Alabama
                  You saw that too huh?
                  Hey, one more post and you hit 6,000!
                  Joab
                  "If nothing else, it will be interesting..."
                  ______________________________________________
                  1979 XS1100SF
                  1972 XS2 650
                  Ozark, Alabama
                  • Eveready1100
                    • 539
                    What I noticed was the chuck key still in the chuck. Might be handy for keeping track of it but it's asking for trouble.
                      Just goes to show you... post count does NOT necessarilly equal knowledge/intelligence.
