Rev limiter?
    • 8797
    Maybe check the mechanical timing advance unit, could be frozen/stuck closed, JAT.
      And after that remove the mouse and his house from the airbox
      Maxim Phil
        Originally posted by BA80
        So you've never had it over 80MPH? With the stock FD 5K is about 60MPH. Come on bug.
        You'd have to have a REALLY short tire as 5K is 75mph(GPS also) on my Venturer. But yea, the motor is definitely "happy" at 5K.......all day long on the 'slab'. Economy seems to start suffering the more above 4200rpm you go, but the grin gets better........
          • 9980
          I'm tellin' ya, on my SG with the 16" tire and the 850 FD 70 MPH is just under 5K. I had to ride from KC to here last summer going by the tach because my speedometer cable snapped.
            Interesting.............as my H is still stock diff.
              Greg, your tach is optimistic.... rpm at 70 mph with a 16" tire and stock gearing is about 4400; you should be right about 4K even with the FD swap...
              • mjpxs11sh
                • Jan 2011
                • 299
                • N/E, Illinois
                rpm
                need more info Jeruel when you come back. just happens i was comparing rpms to my 6spd Honda and my SH was 4k at 60mph with a stock FD and carbs. im always lookin for a 6th gear on the Yammy for some dang reason.
                Max
                81 XS1100SH Black Beast Mutt
                Kerker 4/1
                stock carbs and air box.
                78 headlite, handle bars,
                1 set of ea-160/85mph guages,
                crash bars, cruise control
                Other 2 Wheelers
                78 XS1100E jet kit, Kerker 4/1, air pods, jet kit-RIP
                94 CBR1000F jet kit,Two Bros pipe, K&N Filter
                • JeruelB
                  • Jan 2012
                  • 21
                  • Vallejo, Ca.
                  yes, i think its on the fuel system again. thats what i think, i just have to confirm that it dont have a rev limiter just like my cbr 98 before...the carb was all stock but i just remove the stock airbox and just put individual air filter, i just replace the needle seat due to gas leaking problem,,maybe it was starved w/ gas just because i over do the adjustment of the floater due to excessive leaking of gas before ,,or maybe i have to change the neeedle jet 1st and start from there, any suggestion? my exhaust now is a Kerker 4-1..
                  • James England
                    • 3039
                    • North of England
                    Originally posted by Joab
                    Ahahaha....you and I ride these bikes slower then the actual old men on this forum!
                    You are definitely an ageist, Joab! Just wait til you get there yourself, mate......although at this rate, I reckon I'll be coming to the USA to ensure you don't get much older
                    • Joab
                      • Aug 2010
                      • 472
                      • Ozark, Alabama
                      I do seem to dig into the vintage folk quite often, dont I? Ah well, like you said, willing or not, I will be joining their ranks eventually.
                      And you should certainly come visit...you can help me chop up that old XS2 I have in the shop!
                      Joab
                      "If nothing else, it will be interesting..."
                      ______________________________________________
                      1979 XS1100SF
                      1972 XS2 650
                      Ozark, Alabama
                        • 7941
                          This was my first thought when you said this. What kind of air filters did you put on? If they are the cheap Emgo style where the filter slips onto a boot, then the boot blocks some of your carb jets. Others have said they didn't have problems, but mine would only run up to @ 6500 rpm when I tried them the first time. I can't find the picture that I took of the boot covering the jets, but here's the difference between those and a better set. Notice the throat openings where it goes against the carbs.
                          • Joab
                            • Aug 2010
                            • 472
                            • Ozark, Alabama
                            LOL...James and Marty, the old 650 is safe for now... no chop chop in the near future for it anyhow.
                            Joab
                            1979 XS1100SF
                            1972 XS2 650
                            Ozark, Alabama
                            • Lonerider62
                              • Nov 2011
                              • 187
                              • Gaylord, MI.
                              When I had the opportunity to run my XS for the first time on the open road I was a little surprised to see that according to the tach it was running just about the same RPM at 60 MPH as my FZ1, which is just about 4000. It just seemed strange that yamaha would set up a 1100 cc cruiser to run at the same RPM as a "high energy" sport bike with a little over 100cc less displacement and a tendency to be "pipey". (the FZ1 that is)
                              Can't beat the smell of gas & oil
                              • Joab
                                • Aug 2010
                                • 472
                                • Ozark, Alabama
                                From reading the Bob Jones book, it seemed like Yamaha was getting into uncharted territory with the XS1100... I think perhaps they were still in a bit of "lets see what happens if we do this" phase when this bike was produced. I don't know that they really had sport and cruiser classes back then? Could be wrong though, it was before my time.
                                Joab
                                1979 XS1100SF
                                1972 XS2 650
                                Ozark, Alabama
