79 xs standard
  • Eastcoaster
    • Jan 2012
    • 513
    • oceancity NJ
    79 xs standard
    In the process of a carb rebuild some of the internals are damaged I am looking for a good site to order jets and tubes The tubes are damaged and the needle valves and seats are in bad shape Thanks Are the standard and special the same I have seen conflicting information. I would like to replace them all and do it right and get the right ones. I just can't seem to find a decent site
    Thanks
    82 XJ1100J
    81 Venturer
  • mack
    • 2411
    • Ontario, Canada
    Try
    Georgefix on ebay.
    mack
    79 XS 1100 SF Special
    HERMES
    original owner
    81 XS 1100 LH MNS
    SPICA
    78 XS 11E
    IOTA
    https://youtu.be/wB5Jfbp6SUc
    https://youtu.be/RaI3WYHSuWA
    Frankford, Ont, Canada
    613-398-6186
    • tinman905
      • Aug 2007
      • 946
      • Orangeville,Ontario ,Canada
      George has a web site also http://www.xs650direct.com/
      http://www.mikesxs.net/ is another site you can find some carb parts.
      BDF Special
        • 3193
        Just a note here but the Canadian version of Mikes does not show as XS freindly yet. It may come but the http://www.xs650direct.com site is not yet acknowledging the change. Maybe different owners as well but just so Canadian buyers are aware.
          All 78-79 models use the same needle/seat. If you need emulsion tubes, good luck finding them new, they have been obsolete for some time.
          http://www.partsnmore.com/parts/yamaha/xs1100/?filters[fitting]=custom
            I found some on a site somewhere the other day. I just need to poke around some of the stuff I have saved and find them again.
              Yep, the emulsion tubes should be stamped X-2, and they should be paired with the 5GZ6 needles on the 78-79 carbs. The needles will be hard to find too.
