I received an 850 final with the breather cap broken from shipping damage. Today I successfully pulled the one from the 1100 without damage. They are press fit. I'll mix up a dab of JB Weld and "press fit" the good one into the 850 final.
850 1100 final breather cap swap
1970? Honda Z50... gone
1974 Honda CB200... gone
2008 Honda VTX 1800F
http://www.johnsoldiron.comTags: None
clean pull
how the h did u get that out so cleanly?Max
81 XS1100SH Black Beast Mutt
Kerker 4/1
stock carbs and air box.
78 headlite, handle bars,
1 set of ea-160/85mph guages,
crash bars, cruise control
Other 2 Wheelers
78 XS1100E jet kit, Kerker 4/1, air pods, jet kit-RIP
94 CBR1000F jet kit,Two Bros pipe, K&N Filter
Originally posted by mjpxs11sh View Posthow the h did u get that out so cleanly?Greg
Inquiring minds want to know...1980 XS 11 Special: The King of Kong, 9th wonder of the world. Pacifico fairing, chopped shield, Yamaha hard bags, Diamond seat, T-Kat fork brace, XJ top end, YICS Eliminator, '80 carbs from Spyder Cycle Works, K&N Air filter, Fuse block, stainless steel valves & reg/rect from Oregon MC Parts. Raptor CCT, XJ air shocks, 850 FD, Sportster mufflers, Standard handle bar, Tusk Bar Risers, SS braided brake lines. Cat Eye speedometer. HID projector beam headlight, LED running lights.
All I did was grab it with a pair of channel locks adjusted correctly and very gently started rotating. Once it broke loose I keep rotating back/forth until it loosened up then started working up and out. Small moves, I was really worried about breaking the good one. Practiced on the bad one.1970? Honda Z50... gone
I had the same thing, but I went and bought a new one from the local dealer. I would not suggest using JB weld though. Just a nice tap to get it seated should be plenty to get it to hold.1980 XS850SG - Sold
