850 1100 final breather cap swap
  • WSL91
    • Feb 2012
    • 427
    • Quad Cities, IL
    I received an 850 final with the breather cap broken from shipping damage. Today I successfully pulled the one from the 1100 without damage. They are press fit. I'll mix up a dab of JB Weld and "press fit" the good one into the 850 final.
    1970? Honda Z50... gone
    1974? Yamaha 100 Enduro... gone
    1974 Honda CB200... gone
    1981 Yamaha Virago 750... gone
    1993 Honda Shadow 1100... gone
    2008 Honda VTX 1800F
    1982 Yamaha XJ1100J w/850 final, Raptor ACCT
    1979 Yamaha XS1100SF "Chewey" Raptor ACCT
    http://www.johnsoldiron.com
  • mjpxs11sh
    • Jan 2011
    • 299
    • N/E, Illinois
    clean pull
    how the h did u get that out so cleanly?
    Max
    81 XS1100SH Black Beast Mutt
    Kerker 4/1
    stock carbs and air box.
    78 headlite, handle bars,
    1 set of ea-160/85mph guages,
    crash bars, cruise control
    Other 2 Wheelers
    78 XS1100E jet kit, Kerker 4/1, air pods, jet kit-RIP
    94 CBR1000F jet kit,Two Bros pipe, K&N Filter
      Ditto......I have a broken one too.
      • Poprock
        • Apr 2005
        • 594
        • Oregon Coast
        Inquiring minds want to know...
        • WSL91
          • Feb 2012
          • 427
          • Quad Cities, IL
          All I did was grab it with a pair of channel locks adjusted correctly and very gently started rotating. Once it broke loose I keep rotating back/forth until it loosened up then started working up and out. Small moves, I was really worried about breaking the good one. Practiced on the bad one.
            I had the same thing, but I went and bought a new one from the local dealer. I would not suggest using JB weld though. Just a nice tap to get it seated should be plenty to get it to hold.
