Carb Adjustment
  • Haarstad
    • Sep 2010
    • 95
    • Dexter, MN
    Carb Adjustment
    I went looking for carb adjustment stuff and i couldn't find much for step by step, i did find this site but it isn't quite what i'm looking for. If anyone knows of a place for step by step instructions on where to start, i'd appreciate it if i can get a link.
    I looked up my symptoms hoping to find a thread linking my problem with a solution, and i wasn't having much luck with that either.
    I put different carbs on my bike and it runs like a top at idle and when i'm driving it and i roll the throttle at a low to mid-ranged pace. But when i try to accelerate faster when i'm at a low/cruising rpm, it stutters bad. i don't know what to do next.
    Any info is appreciated.
    Eric Haarstad
    Minnesota
    1979 XS1100 Special
  • TADracer
    • 1417
    • Kenner, Louisiana USA
    I guess the first thing everyone will ask is what different carbs did you put on your bike and how are they jetted. At first blush it sounds like you are lean on the main jets.
    The CV tuning guide you have in your link is a good method if you are willing to do the work. It makes you tune from top down so you are going to be taking your carbs off several times for jet changes to find the sweet spot on all the fuel circuits and the very first thing you will tune for is mains (which may solve your problem).
    One other thing, make sure your ignition and valves are right before you go after the carbs.
    Mike Giroir
    79 XS-1100 Special
    • Haarstad
      • Sep 2010
      • 95
      • Dexter, MN
      The bike is a 79 xs1100 special and the carbs are off of a 78 xs1100. I have pod filters and 4 to 1 kerker exhaust and the jets are 140 across the board for the mains. I don't remember what the signs are when your mains are rich vs lean and I don't remember the signs of the floats being to low or high either. So this is giving me a headache...
      Last summer we got everything new for the ignition and I checked spark yesterday and that was strong, and the valves all look good and are set correctly, we did that towards the end of the season last fall.
      Eric Haarstad
      Minnesota
      1979 XS1100 Special
      • Haarstad
        • Sep 2010
        • 95
        • Dexter, MN
        Also, where should i get my jets and what sizes do you think i should get based on my circumstances?
        Eric Haarstad
        Minnesota
        1979 XS1100 Special
        • mjpxs11sh
          • Jan 2011
          • 299
          • N/E, Illinois
          jets
          hey Haarstad, i sent u a private message with intake/exhaust mod jet specs and a factory pdf manual so u know what was in the carbs from the factory. i bought my Mikuni jets (which is a must) from nichecycle.com
          Michael
          Max
          81 XS1100SH Black Beast Mutt
          Kerker 4/1
          stock carbs and air box.
          78 headlite, handle bars,
          1 set of ea-160/85mph guages,
          crash bars, cruise control
          Other 2 Wheelers
          78 XS1100E jet kit, Kerker 4/1, air pods, jet kit-RIP
          94 CBR1000F jet kit,Two Bros pipe, K&N Filter
          • SFerinTEXAS
            • Jun 2006
            • 877
            Have You Yourself pulled these NEW carbs apart and know are Good To GO? From this post that essential point is not clear.It is essential.
            79SF
            XJ11
            78E
            • Haarstad
              • Sep 2010
              • 95
              • Dexter, MN
              Yup, i follow the disassembly guide on this website and tore them down and cleaned them all up
              Eric Haarstad
              Minnesota
              1979 XS1100 Special
              • Haarstad
                • Sep 2010
                • 95
                • Dexter, MN
                Are these the correct main jets, and these are the correct pilot jets? then i just pick my size(s) i want?
                Eric Haarstad
                Minnesota
                1979 XS1100 Special
                  Pilot jets are correct main jets are wrong. You linked to the small round main jets and those are used as the air jets in the In take bell of the carb but are too small further main fuel jet. These are correct for the main fuel jet http://nichecycle.com/ProductDesc.as...ain-jet&key=it
                    • 5062
                    Why not get the larger headed mains to match stock? However, functionally, I believe the smaller diameter will also work well as I have used them.
                    • Haarstad
                      • Sep 2010
                      • 95
                      • Dexter, MN
                      Sounds good, i'll order a couple sizes tonight. Thank you very much
                      Eric Haarstad
                      Minnesota
                      1979 XS1100 Special
