79 Special starting to Shake under Accel
  • 79xs1100s
    • Aug 2009
    • 115
    I get a strange Shaking feeling in the bike under load/ acceleration. around 40mph and up when on the throttle. It seems to go away if I pull in the clutch so I'm thinking it is drive line related rather than wheel bearing/chassis but I could be wrong. Is there any way to rule out Transmission, Clutch, Differential, etc? Any Help or suggestions are appreciated.
    Bike has about 28k miles on it.
    New Tires front and rear
    Never changed the wheel bearings.
    Never serviced the Middle or Differential drives.
    Thanks
    Mark
    XS11.Com resident Black Sheep
    Carefully pull back the boot around the driveshaft u-joint and check it for looseness; if the u-joint is going bad, that could be it...
      Same symptoms I had when my U-joint was bad. REALLY bad.
        Don't have that issue, but could one assume and make a mental note of that being a sign of a posible u-joint going array?
        • ddragon63
          • Jan 2012
          • 1101
          • Ridgefield, WA
          did it start after you installed new tires?
          Don
          old:
          1989 kawi ex500
          1996 yzf-r6
          1999 yzf-r1
          2001 kawi zx-6r
          2000 Ducati 748
          2002 YZF-R1
          2005 V-Star 1100 Classic
            Just read this in your post..
            Have you even checked them? 28k miles and 30+ years, ya think it might be ready for an oil change in there?
              It would be a good idea to do a check/change on the MD/FD....... but if that's the vibration I don't think that will fix it...
              • mmaddix
                • Jul 2011
                • 232
                • Beaufort, SC
                I had a similar problem. I felt a vibration more on my feet than the whole bike and I only felt it when I jumped on the gas but mine was at higher speeds. I would get am increase in RPMs but no acceleration until I let off the throttle a little. Mine was the clutch slipping. All I needed to do was adjust the clutch cable and do the mechanical adjustment.
                I know your problem might be different but of you have any of the symptoms I had then I would check the clutch adjustment.
                USMC 2005 - Present
                79 XS1100F -Mileage unknown - Clubman bars, aftermarket headlight and speedometer, 4 into 1 straight through exhaust, TopCat's fuse box, 1980G rear fender - Daily driver - My first Motorcycle
                78 XS1100E - Rebuilt And Sold I SHOULD OF KEPT IT!!!
                  Agreed, and wasn't saying that would fix it, just that it needs to be done. I would suggest checking that the the drives aren't empty. Hate to see anyone with a middle drive lockup at speed. It tends to make new members of the "Over the Handlebars Club"
