So I'm going to sand blast my tank what kind of primer should I use since I won't be able to paint the tank right away . And I don't want it to rust.
primer question
If you're just looking for a rattle-can primer, I've had very good luck with the Rustoelum primers...Last edited by crazy steve; 04-04-2012, 11:21 AM.Fast, Cheap, Reliable... Pick any two
+1 what Davinci stated.......which is the ONLY correct primer to use on bare metal before color anyways........BTW, seems east of the Rockies, you guys are stuck on that Rustoleum crap, or maybe cause of stricter EPA regulations that's all you can get........Last edited by motoman; 04-04-2012, 12:13 PM.81H Venturer1100 "The Bentley" (on steroids) 97 Yamaha YZ250(age reducer) 92 Honda ST1100 "Twisty"(touring rocket) Age is relative to the number of seconds counted 'airing' out an 85ft. table-top.
Originally posted by DAVINCI View Postfor bare metals, look for the words 'self-etching' on the canNathan
[QUOTE=motoman;365830........BTW, seems east of the Rockies, you guys are stuck on that Rustoleum crap, or maybe cause of stricter EPA regulations that's all you can get........[/QUOTE]
I like it because it's the only primer I've found that isn't porous; if a primered part is going to sit for a while (which is what he's asking about), it's the only one I've found that won't have rusting issues...Fast, Cheap, Reliable... Pick any two
Originally posted by GARTHXS View PostSo I'm going to sand blast my tank what kind of primer should I use since I won't be able to paint the tank right away . And I don't want it to rust.1970? Honda Z50... gone
1974 Honda CB200... gone
2008 Honda VTX 1800F
http://www.johnsoldiron.com
Originally posted by WSL91 View Post2 part epoxy automotive. Its bulletproofSeamus Ó hUrmholtaigh
Niimi Moozhwaagan
and SOXS
2008 Nomad "Deja Buick'
Originally posted by WSL91 View Post2 part epoxy automotive. Its bulletproof1980 XS850SG - Sold
Originally posted by CatatonicBug View PostThis brings up a question I was hoping to have answered by this thread. Is it OK to use "cheap" rattlecan primer under a nicer, 2-part finish? Don't you need to have a primer that is compatible with or similar in structure to the paint layer?
I'm sure some will disagree, but that's worked for me....Last edited by crazy steve; 04-05-2012, 04:12 PM.Fast, Cheap, Reliable... Pick any two
so as I posted before , I sand blasted the tank and put a coat of primer on it . today I slapped some bondo on and filled the badge divots then another coat of primer!! still needs some sanding and a couple of small holidays filled but all in all pretty good .
sand blasted
one coat
and almost final coat of primer the holidays and small indent is barely noticeable . but it needs another fill and skim.
but im done for today.91 kwaka kz1000p
Stock
( Insert clever quote here )
What?
You have a spray booth?You can't stay young forever, but you can be immature for the rest of your life...
Drilled airbox
Tkat fork brace
Hardly mufflers
late model carbs
Newer style fuses
Oil pressure guage
Custom security system
Stainless braid brake lines
I have access to a legal booth, right here http://www.makerplace.com/
nice to hear from you Dick . havent been in touch in a while!91 kwaka kz1000p
Stock
