So I'm going to sand blast my tank what kind of primer should I use since I won't be able to paint the tank right away . And I don't want it to rust.
primer question
If you're just looking for a rattle-can primer, I've had very good luck with the Rustoelum primers...Last edited by crazy steve; 04-04-2012, 11:21 AM.Fast, Cheap, Reliable... Pick any two
Yep, can't leave nuthin' alone... -
+1 what Davinci stated.......which is the ONLY correct primer to use on bare metal before color anyways........BTW, seems east of the Rockies, you guys are stuck on that Rustoleum crap, or maybe cause of stricter EPA regulations that's all you can get........Last edited by motoman; 04-04-2012, 12:13 PM.81H Venturer1100 "The Bentley" (on steroids) 97 Yamaha YZ250(age reducer) 92 Honda ST1100 "Twisty"(touring rocket) Age is relative to the number of seconds counted 'airing' out an 85ft. table-top.Comment
Theodore RooseveltComment
[QUOTE=motoman;365830........BTW, seems east of the Rockies, you guys are stuck on that Rustoleum crap, or maybe cause of stricter EPA regulations that's all you can get........[/QUOTE]
I like it because it's the only primer I've found that isn't porous; if a primered part is going to sit for a while (which is what he's asking about), it's the only one I've found that won't have rusting issues...Fast, Cheap, Reliable... Pick any two
1970? Honda Z50... gone
1974? Yamaha 100 Enduro... gone
1974 Honda CB200... gone
1981 Yamaha Virago 750... gone
1993 Honda Shadow 1100... gone
2008 Honda VTX 1800F
1982 Yamaha XJ1100J w/850 final, Raptor ACCT
1979 Yamaha XS1100SF "Chewey" Raptor ACCT
http://www.johnsoldiron.comComment
Seamus Ó hUrmholtaigh
Niimi Moozhwaagan
NOTICE: No trees were destroyed in the sending of this message. We do concede, however, that a significant number of electrons may have been inconvenienced.
Any connection between your reality and mine is purely coincidental.
Member of "FOXS-11" (Former Owner of XS-11)
and SOXS
2008 Nomad "Deja Buick'Comment
This brings up a question I was hoping to have answered by this thread. Is it OK to use "cheap" rattlecan primer under a nicer, 2-part finish? Don't you need to have a primer that is compatible with or similar in structure to the paint layer?1980 XS850SG - Sold
-H. FordComment
The pros and the paint manufacturers will all tell you yes, the primer should 'match' the top coat. And it probably is the best way to do it. But I've had good luck with good (not the really cheap crap) rattle-can primer under quality 2-part paints, and I know other people who have too. One 'mistake' I see done time and again is sanding the primer with too-fine paper. Guys will wet-sand with up to 600 grit paper then apply the finish coat. Not good; the primer is too smooth, so smooth that the color coat doesn't have any 'tooth' to grip so it will chip/peel easily; BTDT. You shouldn't use anything finer than 320 on your primer, and 220 would be better; best is don't sand it at all. You'll need to put a bit more color-coat on to 'fill' the scratches left by the paper, but the paint will grip much better. If you're planning on color-sanding the final paint, that will take out any scratches that may be left...
I'm sure some will disagree, but that's worked for me....Last edited by crazy steve; 04-05-2012, 04:12 PM.Fast, Cheap, Reliable... Pick any two
so as I posted before , I sand blasted the tank and put a coat of primer on it . today I slapped some bondo on and filled the badge divots then another coat of primer!! still needs some sanding and a couple of small holidays filled but all in all pretty good .
sand blasted
one coat
and almost final coat of primer the holidays and small indent is barely noticeable . but it needs another fill and skim.
but im done for today.91 kwaka kz1000p
Stock
( Insert clever quote here )Comment
What?
You have a spray booth?You can't stay young forever, but you can be immature for the rest of your life...
Drilled airbox
Tkat fork brace
Hardly mufflers
late model carbs
Newer style fuses
Oil pressure guage
Custom security system
Stainless braid brake linesComment
I have access to a legal booth, right here http://www.makerplace.com/
nice to hear from you Dick . havent been in touch in a while!91 kwaka kz1000p
Stock
