so i was working on my bike, and i turn the key off, but it stays running...i hit the kill switch to stop the motor, take the key out, and the power stays on...i start the bike, and with the key in the on position, i can remove the key, bike stays on...with the key in the off position, the bike stayed running, even after removing the key...holy crap! whats the deal?
I swear if its not one problem its another....
79 XS11 special "Loki" - homemade 4-2 exhaust, pod filters, rebuilt forks with progressive springs, tkat fork brace, progressive shocks, rebuilt all brakes and MC's, rebuilt carbs with #142.5 main and #42.5 pilot, a custom front and chin fairing, and a handmade set of saddlebags....
09 YZF-R1 " Toothless"
04 Buell XB12R "Butterfly"
"I had a name at some point, a birth-name, but now everyone just calls me Wolf...."
Wolf
Moto Militia MCTags: None -
nevermind i found the problem...the fuse box had somehow grounded itself out against the metal frame it connects to...
however, should i be able to remove the key while in the on position?79 XS11 special "Loki" - homemade 4-2 exhaust, pod filters, rebuilt forks with progressive springs, tkat fork brace, progressive shocks, rebuilt all brakes and MC's, rebuilt carbs with #142.5 main and #42.5 pilot, a custom front and chin fairing, and a handmade set of saddlebags....
Wolf
Moto Militia MC -
Don't know if that's correct or not, but the key has come out of my Venturer's ignition while on, for some 30+ yrs. now........81H Venturer1100 "The Bentley" (on steroids) 97 Yamaha YZ250(age reducer) 92 Honda ST1100 "Twisty"(touring rocket) Age is relative to the number of seconds counted 'airing' out an 85ft. table-top.Comment
Hmm...fuse box grounded out, keeps bike running with key off. I do nto follow how that would be the solution. Likely is your key switch is not operating correctly.
I am miles and miles form my XS, so I can't go check, but it seems to me the key will not remove unless it is turned off, or to lock. Not certain though.
I would take the key switch apart and clean and check it. Not to tough to do really.Life is what happens while your planning everything else!
78 XS750Comment
The key often comes out when in the ON position. It's not actually supposed to but they often do. Mine did.XS1100F 1980 European model. Standard. Dyna coils. Iridium plugs. XS750 final drive (sometimes). Micron fork brace. Progressive front springs. Geezer regulator/rectifier. Stainless 4 into 2 exhaust. Auto CCT (Venturer 1300) SOLD. New project now on the go. 1980 European model.Comment
As the pins in a tumbler and the landings on a key wear out a key can eventually be removed when it is not supposed to be. My XS key comes out, I have owned several vehicles where I could pull the key out. Not a big deal. Until the day the key won't turn.the lock anymore.
I would suggest pulling the lock though and cleaning it and lubing it all up.Nathan
Theodore RooseveltComment
I would suggest pulling the lock though and cleaning it and lubing it all up.81H Venturer1100 "The Bentley" (on steroids) 97 Yamaha YZ250(age reducer) 92 Honda ST1100 "Twisty"(touring rocket) Age is relative to the number of seconds counted 'airing' out an 85ft. table-top.Comment
That's when it happens, if it happened to yours new then there was something else.Nathan
There is your 'something else...........Last edited by motoman; 04-04-2012, 03:54 PM.81H Venturer1100 "The Bentley" (on steroids) 97 Yamaha YZ250(age reducer) 92 Honda ST1100 "Twisty"(touring rocket) Age is relative to the number of seconds counted 'airing' out an 85ft. table-top.Comment
That would be scary... I can imagine going down the highway, and hit a bump, and there go your keys!I lost radio knobs and a side cover that way...
-H. FordComment
Happened once many years ago hitting a 'wheel popper' pothole at 50mph, and snapped of the flip-up plastic cover on stereo. Saw the key-set skidding on pavement in mirror and retrieved them. Bought another stereo cover so it could be snapped off again same scenario two weeks later. Decided didn't need that cover so bad after all. Now has a felt lined vinyl soft cover that slides over stereo, covers speakers and snaps to fairing at speaker ends. Called SOUND IDEA on top front of cover in bold letters. Have never seen another one like it since. Even having Polk all-weather speakers, it sure keeps all that area looking new underneath. Even the carwash has no ill-effect being covered like that.81H Venturer1100 "The Bentley" (on steroids) 97 Yamaha YZ250(age reducer) 92 Honda ST1100 "Twisty"(touring rocket) Age is relative to the number of seconds counted 'airing' out an 85ft. table-top.Comment
