Sumitomo Brake Pads
    • 1591
    Sumitomo Brake Pads
    Question: Ever heard of anyone using Sumitomo Brake Pads for the Front Brakes on a 78' XS1100 E??
    PO or somebody had put in Sumitomo A8K A21 66 in both front brake calipers. Could be maybe Sumitomo ASK A21 GG since it is a bit hard to see. Looks to me to be Auto Brakes and Google search doesn't give me much info.
    PO had Bleed Screws loose but brakes still really ON..... It is difficult to move the bike around the garage with the brakes stuck. Rotor is centered in the Caliper on the right side, but Left rotor is dragging/scraping on the outboard side of the left Caliper body. What I'm seeing makes no sense.
    Nothing looks bent or misaligned. Both Rotors are OK and would be all ripped up if the bike was actually ridden this way. Bleed screw on right was already loose so I removed the Bolts holding on the Calipers. Even with the bolts off and no pressure on the line the brake pads it still has a major bite on the brake rotor.
    I ordered XS1100E Master Cylinder rebuild Kit and Caliper rebuild Kits today so I plan to get to the bottom of the puzzle. Maybe the Sumitomo A21's worked for a while then after they wore down a bit a retainer may have jumped or bent. Just wondering if anyone has any experience or info about the Sumitomo pads.
    Thanks, Jeff
    I believe Sumitomo was OEM....
      The front end probably isn't aligned properly.
        • 1591
        [QUOTE=natemoen;365499]The front end probably isn't aligned properly.[/QUOTE
        Yes, that might be it! If Sumitomo A21 was the OEM brake pad then that is not the issue. After further inspection I see the PO had not had the front axle off anytime recently. Rotors have never been off. Forks are not bent. If nothing is bent -and- the right caliper will not come off easily and the left rotor is scraping the caliper body; then misaligned forks is a top candidate.
        This the is $450 "Save" bike I got in Louisville in January. I've rebuilt carbs and got the parts to r&r the petcocks arriving Friday. Bike seems to have had good dealer maintenance for a long time without any major PO hacking. Seems like just a few goofy things done in the last year or so as the bike was neglected and somebody tried to 'get her running'. So far, so good with the refurbishment. With the symptoms I've described, I think you are right about the whole front end alignment. The electrical tape in lieu of fork seal rubber covers might be an indication of what I need to fix next after R&R the Master Cylinders and Calipers.
        Thanks, Jeff
        • WSL91
          • Feb 2012
          • 427
          • Quad Cities, IL
          Possible stuck piston in the caliper as well
          1970? Honda Z50... gone
          1974? Yamaha 100 Enduro... gone
          1974 Honda CB200... gone
          1981 Yamaha Virago 750... gone
          1993 Honda Shadow 1100... gone
          2008 Honda VTX 1800F
          1982 Yamaha XJ1100J w/850 final, Raptor ACCT
          1979 Yamaha XS1100SF "Chewey" Raptor ACCT
          http://www.johnsoldiron.com
