high pitched hum when im on the gas....
  • airborneXS
    • Feb 2012
    • 338
    • Houston, TX.
    I noticed today that i have a high pitch whine under power, and i can only here it when i give it gas and at lower than 40 mph....after that it gets drowned out by the wind and the kerker exhaust....any ideas? maybe the middle drive? i know that i need to replace my middle drive boot, as it has a gaping hole in it....
    79 XS11 special "Loki" - homemade 4-2 exhaust, pod filters, rebuilt forks with progressive springs, tkat fork brace, progressive shocks, rebuilt all brakes and MC's, rebuilt carbs with #142.5 main and #42.5 pilot, a custom front and chin fairing, and a handmade set of saddlebags....
    09 YZF-R1 " Toothless"
    04 Buell XB12R "Butterfly"
    "I had a name at some point, a birth-name, but now everyone just calls me Wolf...."
    Wolf
    Moto Militia MC
    • 3192
    The middle drive boot does have a drain hole in it although it could not be described as Gaping.
      • 9980
      The whine is probably just the transmission. The straight cut gears make that noise.
      It's normal. You'll get used to the noises.
      BTW....Get a new boot HERE
      • airborneXS
        • Feb 2012
        • 338
        • Houston, TX.
        andreas has a new boot for me...its at least a 50 cent piece hole...so the whine is not me about to detonate anything? lol...
        Wolf
        Moto Militia MC
          • 9980
          It sounds like a normal gear whine to me. You'll hear it at highway speeds too reflecting off of concrete bridge railings.
          Kinda freaks you out until you get used to it.
          • CWLindeman
            • Feb 2012
            • 12
            • Waynesburg, Penn.
            Maybe thats the noise I keep mentioning and everyone either shrugs with a confused look or says don't worry about it. It's like a whizzing from the inside. Iguess it really isn't anything to worry about.
            • James England
              • 3039
              • North of England
              They're noisy engine (mechanically). I would worry about it. Many other bikes, more modern ones too, make an even more pronounced transmission whine. I like the sound!
              • XJkid
                • Jun 2003
                • 280
                • Elk Grove, Ca.
                Mine makes a sound like a cricket chirping at around 40 mph. I thought it was the speedo cable. Could that also be the trans?
                  That ain't right...
                  • warfman41
                    • Mar 2012
                    • 22
                    • Glasgow ky.
                    mine too
                    must be a normal thing, cause mine does it too. And i agree with James, i kinda like it myself.
                    Warfman41 1979 xs 1100 F newly aquired...getting it road ready.
                    • TADracer
                      • 1417
                      • Kenner, Louisiana USA
                      Whine or hum??
                      Over the years my machine has made both. The whine is normal from the gear mesh in the tranny, mostly in 4th gear on mine. Angle cut gears would quiet this but they are much more expensive and also cause thrust bearing issues so, straight cut gears are the norm.
                      The hum on the other hand can occur with the speedometer cable because the input socket on back of the speedometer needs some lubrication. The hum is caused by the squared portion at end of the cable spinning in the socket at the speedo drive on the front wheel. The cable will break off there but the problem is at the opposite end of the cable.
                      Mike Giroir
                      79 XS-1100 Special
                      • Bassman
                        • Aug 2012
                        • 59
                        • Fort Collins, CO.
                        @TADracer I think that I am having this problem. As I was riding home from work yesterday, I noticed a whine/hum from the front end. I found that the speedometer was what was humming since the humming would lessen when I grabbed the speedo and stabilized it.
                        What is the best way to lubricate the speedo and speedo cable?
                        thanks
                        -Andrew
                        80 XS11 G: Project bike
                        • XJkid
                          • Jun 2003
                          • 280
                          • Elk Grove, Ca.
                          I found that my speedo cable was on too tight.It had been making a humming/growling noise and my first inclination was to grease the end and tighten the "nut" where the cable goes into the speedo. When that didn't work, I loosened it and it stopped.
                          • CaptonZap
                            • Jun 2010
                            • 1748
                            • Denver
                            thanks
                            The speedo cable is easy. Take the whole thing off, and remove the inner cable. Take some carb cleaner, and douche out the inside of the outer housing. Take some solvent, and wash the inner off thoroughly.
                            Take some Dri-Slide, or lock lube with graphite, and soak inner and out with it.
                            Reinstall, and you are good to go. It won't act funny in cold weather that way.
                            The speedo is another story, and you can check past posts for methods of doing that.
                            CZ
                            • MPittma100
                              • Aug 2011
                              • 2359
                              Hum
                              Mine does it too. I just HUM along with it or turn the radio up! LOL
                              MP
                              1981 XS1100H Venturer
                              K&N Air Filter
                              ACCT
                              Custom Paint by Deitz
                              Geezer Rectifier/Regulator
                              Stebel Nautilus Horn
                              EBC Front Rotors
                              Limie Accent Moves On In 2015
                              Mike
