Clutch adjustment screw
  • Pancala
    • Jan 2012
    • 67
    • Shawnee, OK
    I was getting excited as I had my bike finally finished and running in my living room, last thing to do was start her up on the centerstand and test the new clutch cable I installed. After I started her I grabbed the clutch and pushed it down to first, she gave a jerk and the back tired started spinning... I thought well okay, clutch adjustment is off. I pulle the side cover and found the adjustment screw almost stripped out completely due to the PO
    I tried adjusting it per the manuals instructions and still could not get the clutch handle to do anything. Is it possible to change the adjusting screw without taking the side of the tranmission off? Anything else I'm not doing? I feel the resistance and backed it off a 1/4 turn, then tried 1/8th. Nothing. And if I do need to replace the adjusting screw does anyone happen to have one for cheap? Boats.net has them bit it'll be about 17.00 after shipping.
    Thanks for the help!
    Justin
    1980 XS1100SG(First bike, sold)
    Other bikes
    1976 Kawasaki KZ400 (project)
    1983 Yamaha XV920 Midnight Special
    1984 Yamaha XT250 Enduro (project)
  • DeanR
    • Jan 2005
    • 1495
    • Finger Lakes NY
    gotta love it..
    good luck
    80 SG
    81 SH in parts
    99 ST1100
    91 ST1100
      • 8050
      Did it look like this?
      If it was my bike, I would replace the adjusting screw. Buy a few more parts to defray the shipping cost. I have the listing for you below. They usually ship cheaper than what you'll pay at boats.net.
      Yamaha Sports Center
      • hamjam
        • 1003
        • Toronto ontario Canada
        fire it up, I usually turn the range hood exhaust fan on
        pull in clutch ,put in gear , hold clutch in put rear break on , if the revs drop drastically or it stalls then you have a mal adjusted clutch otherwise take it outside for a ride , remember to turn the range hood exhaust off
        Seamus Ó hUrmholtaigh
        Niimi Moozhwaagan
        and SOXS
        2008 Nomad "Deja Buick'
          • 8050
          So Hamjam, I take it you choose to run in the kitchen rather than the living room.
          • hamjam
            • 1003
            yes.... no carpet
            Niimi Moozhwaagan
            and SOXS
            • hamjam
              • 1003
              oh curses .... I just re read my first posting and found the spelling mistake please do not break the brake
              Niimi Moozhwaagan
              and SOXS
              • TomB
                • Aug 2006
                • 967
                • Cumbria, UK
                If you don't want to take out the screw use an angle grinder with thin cutting disc to cut a flat blade screwdriver slot in the end.
                Tom
