Pinhole Repair
  • clcorbin
    • Jan 2010
    • 495
    • Albuquerque, NM
    These photos do make me feel better about my own tank! I thought it was almost at the end of it's life and it had less than a 1/4 as many holes! My hat is off to you!
    -- Clint
      Originally posted by Lonerider62
      ....Even if all the repaired holes are good, I'd expect there are places not yet discovered that will end up leaking.
      Oh, I dunno... If the tank is cleaned out good then sealed properly, I don't see why it couldn't last as long as any other tank. Although I will confess a bit of curiousity as to why these holes even needed filling. I would think that a good epoxy liner would have sealed the holes from the inside, then a skim coat of plastic to take care of the outside surface issues would have fixed that. If you don't get the internal rust stopped in it's tracks, anything else you do won't help...
        There isn't any rust inside, but I think the PO cleaning out the rust with whatever is what helped cause the holes.
        • clcorbin
          • Jan 2010
          • 495
          • Albuquerque, NM
          Electrolysis can do that. The rust is in place, but compacted enough that it is basically filling the hole where it rusted out the pin hole. When you hit it with electrolysis, it pulls out all rust and you now a LOT of holes that you didn't know actually existed.
          -- Clint
            • 5050
            If you are going to spend a lot of time and money lining and painting, save some headaches and start with a better tank!
