So I had recently acquired a Venturer tank. When I got it, it looked amazing. Inside was super clean. The paint thpugh was super thick and gooy. After lots of stripe and laquer thinner I found out why the paint was so thick. It was to cover up all the JB Weld and epoxy paste used to fill the the plethora of pinholes...
So, since it is a Venturer tank I am not going to let it go. So that means it is time to start filling holes, and lots of them!
So to start off I took the tank down to bare metal and sanded the area with 60 grit sandpaper so that there would be something for the metal filler to stick too. I then took a automatic center punch and used that to pop out the epoxy and to dimple the area around the hole.
After finding and opening all the holes up I cleaned and sanded the area again. For now I am using up some lead free body leading compound, you could also use solder for this and I will end up having to use some solder anyways.
On a safety note: ONLY use LEAD FREE compounds or solder. You will need to be standing this and if you sand leaded material you will then have lead in the air and you don't want to be breathing lead in. Wear a mask ot respirator no matter what though.
At this point apply some leading butter or flux depending on the filler you are using. Heat the area around the holes nice and hot, I am using a small butane torch for this. Then apply the filling compound and just keep going filling holes. As the area gets hot your butter/flux will start burning. Let things cool some and hit it with a wire brush to knock off any loose filler and them wipe the area clean again and put some new butter/flux on. Then just keep repeating till you have all the pin holes filled.
Now since I don't have the paddles for body lead it ends up a bit clumpy, more like it would if you are using solder. You can get it pretty smooth if you have the paddles. So it will look a lot like this.
At this point you can take a rasp or a bastard file to it and start bringing it down to smooth it out. As you go you may find some holes that didn't get filled in completely and you may need to redo some. After you have it all filed down sand it for the finishing touches. I would suggest filling the tank with gas at this point and letting it sit to make certain all the holes are filled and sealed. Also especially in this case with so many holes like this tank I would put a liner in the tank. I personally use Red-Koat epoxy liners and have never had one fail. You can treat the tank as you would any other tank once you have all the holes filled when it comes to paint.
I will keep adding pics as I go along and fix this tank up.
