I 've been trying to get my carbs lined out, and had made a couple of 5 minute test rides to evaluate. After remounting the carbs this weekend, I just fired her up and got nasty cam chain noise. I hadn't heard it after my last test ride a few days ago. It was previously set to factory spec. I loosened the cct bolt and heard it take up slack. When refired the noise is gone. Is the factory spec torque on the cct bolt of 4.3 ft.lb enough? Has anyone else had this happen?
oem cct backed out......
Yep, can't leave nuthin' alone... -
Thanks Steve. I did some forum searching but must not have been thorough enough. Whoah, I must have gotten lucky.
I shift up after hard accelerations when testing, but should probably pull in the clutch. Hopefully she'll be ok. I have a 660 Raptor tensioner in the garage. I guess it's time to put it on huh?
Airbox w/K&N element
Jardine 4 into 1
145 mains, 45 pilots
1996 Ducati 900SS CR
1977 Kawasaki KZ900-A5
1975 Honda CB550KComment
Sooner the better. Put one on my SG a month ago. He likes it a lot. Set it forget it.1980 XS 11 Special: The King of Kong, 9th wonder of the world. Pacifico fairing, chopped shield, Yamaha hard bags, Diamond seat, T-Kat fork brace, XJ top end, YICS Eliminator, '80 carbs from Spyder Cycle Works, K&N Air filter, Fuse block, stainless steel valves & reg/rect from Oregon MC Parts. Raptor CCT, XJ air shocks, 850 FD, Sportster mufflers, Standard handle bar, Tusk Bar Risers, SS braided brake lines. Cat Eye speedometer. HID projector beam headlight, LED running lights.Comment
