mixture screws
  • imcgyver
    • Oct 2011
    • 27
    • Denver, COLO.
    mixture screws
    Hello I am having a hard start issue when cold, runs great warmed up, question I do not know what the factory settings for the mixture screws are, I have mine 3 turns out and acting like a lean mixture, I do have a set of 45 pilot jets if I need to go richer, 42.5 installed now.
    would the mixture screw orings be an issue?
    trying to get ready for sping, summer and fall riding.
    thank you for your time and response.
    Ron
  • Rasputin
    • 3189
    • Lacombe, Alberta, Canada
    Check your enricher circuit if it is doing that. Pay special attention to where it draws from in the carb bowls as that is known to plug up.
    If my mixture screws are between 2 and 4 1/2 turns out I am fine with them. Others may have different ideas but that is where mine are happy. I have fine cold start, nice idle and 48MPG (Canadian/UK gallon) the way I set them. I use a colortune to set them initially and then go by plug color after that for all ranges of my riding. Time consuming and a bit of a PITA but hey the damn thing is a rocket.
    2-79 XS1100 SF
    2-78 XS1100 E Best bike Ever
    • petejw
      • 2269
      • sydney australia
      if shes running sweet when the bikes warmed up
      leave the jets alone,
      as ras stated check ur float bowls, theres a small
      jet that can block up and cause hard starting.
      pete
      new owner of
      08 gen2 hayabusa
      former owner
      1981 xs1100 RH (aus) (5N5)
      zrx carbs
      18mm float height
      145 main jets
      38 pilots
      • XJfan1
        • Feb 2012
        • 180
        • Huntington,Indiana
        How high should the bike rev when the choke is fully turned on? When the bike is warm it only revs to about 2500 rpms. Seems like it used to rev higher before I treated it with sea foam.i dont have the cash to buy the sync tools and I'm scared to let anybody mess with it. it runs well but I'm wondering if it could be better. And my milage is terrible. I noticed today that the exaust pipe on the right side going into the silencer is turning blue. Us that a indication of being plugged with goo. The exaust is factory with 33 thousand on it.
        1982 xj 1100
        "The Ape"
        http://youtu.be/AiQ8CqclHr4
        • petejw
          • 2269
          • sydney australia
          2500 should be fine, a blueing pipe is usually an indication
          of a lean mixture, pull ur plugs out and see what they look like.
          pete
          new owner of
          08 gen2 hayabusa
          former owner
          zrx carbs
          18mm float height
          145 main jets
          38 pilots
          • XJfan1
            • Feb 2012
            • 180
            The plugs looked good the other day when I looked at them. Wouldn't it turn blue at the head not by the muffler.and its only on one side not both.being its got the original crossover pipe. Id think both sides would turn blue if that were the case.
            1982 xj 1100
            "The Ape"
            • petejw
              • 2269
              • sydney australia
              if the plugs look good, then u should be sweet,
              it could be that the pipe is a bit thinner at the part
              thats turning blue.
              pete
              new owner of
              08 gen2 hayabusa
              former owner
              zrx carbs
              18mm float height
              145 main jets
              38 pilots
                If you are blueing a set of double walled stock pipes there is a problem!
                • XJfan1
                  • Feb 2012
                  • 180
                  Thats what I'm asking. Why would it blue at the muffler? if it was lean wouldn't it blue at the head?
                  1982 xj 1100
                  "The Ape"
                    If the bike is running rich, that can put unburned fuel into the exhaust. It can then ignite, causing blueing at the point of ignition...
                      +1. I missed the part about it being in the muff itself.
