clutch issues....
  • dpotter58
    • Aug 2004
    • 1846
    • Southern Maryland
    Originally posted by airborneXS
    so apparently there are 2 different cables....the specials use a shorter one...i was supplied 2 cables from 2 different members, one was a little longer than the other....originally i didnt check this out, so i removed the cable, checked the lengths, and one was a little shorter...i installed the shorter on, cleaned the adjustment screw, and everything seems to operate correctly...i am now just waiting on the rtv to dry before testing it...i will let yall know...
    so which one worked? I have another like the one i sent you in my saddle bag and would hate to find out its not right while out on the road and I'm too lazy to pull the one of the bike to check it. The one i sent should have fit your sg.
    1980 LG
    1981 LH
    • airborneXS
      • Feb 2012
      • 338
      • Houston, TX.
      i need to figure it out...i got one from you and one from another member...the shorter one worked for the special...its only like 1/2" shorter, but that little bit made all the difference in the world...
      79 XS11 special "Loki" - homemade 4-2 exhaust, pod filters, rebuilt forks with progressive springs, tkat fork brace, progressive shocks, rebuilt all brakes and MC's, rebuilt carbs with #142.5 main and #42.5 pilot, a custom front and chin fairing, and a handmade set of saddlebags....
      09 YZF-R1 " Toothless"
      04 Buell XB12R "Butterfly"
      "I had a name at some point, a birth-name, but now everyone just calls me Wolf...."
      Wolf
      Moto Militia MC
        Could easily rout the slightly longer on different to take up that extra length
        • airborneXS
          • Feb 2012
          • 338
          • Houston, TX.
          ive got the shorter one in and clutch adjusted, it rides smooth as butter now...thank u everybody for your help...so now i have a longer clutch cable if anybody needs one...( im guessing its a standard cable, and the special is the slightly shorter cable?)....
          Wolf
          Moto Militia MC
            Glad you go tit working, that is the key issue no matter what the cable length. However, I would think if one is shorter than the other, the Standard would be the shorter, due to the difference in handle bars between the Standard and the Special.
            • James England
              • 3039
              • North of England
              I think the guy's private life really is his own affair.
                Yeah, I was cruising down Ocean Bullevard, when my Sting Ray started acting up, I took it to the Shell station, the guy said I had blown a seal. I told him to fix the car and leave my perosnal life out of this!!
