Fuel T's
  • Duster
    • Jun 2003
    • 43
    • Central Texas
    Fuel T's
    HA Guys: Does anyone have a resorce for the inline fuel T's that are the same as what came on the xs. I've found larger plastic and brass 1/4" T's but the inside diamator is alot smaller. None of the bike or auto parts local have the right kind.
    Duster
    79 XS1100 SF & 1989 Venture Royal & 98 Valkrye
    It's not the speed that will get you it's the sudden stop.
  • mitch
    • Oct 2002
    • 934
    Tees
    I found some at an auto scrap yard, they were used on the lines going to the poullition control system, sorry cant remember what type of car but i just kept opening hoods till i found what i needed lol HTH......MITCH
    Doug Mitchell
    82 XJ1100 sold
    2007 Stratoliner 1900 sold
      The 1/4 tees should work fine. I just eliminated the octopus on my bike, and replaced the lines with 1/4 inch urethane lines, and 1/4 inch 'Y' fittings. Before that, I only opened one petcock, and kept the other one in the off position, and never had a fuel starvation problem. I ran the new lines directly from each petcock to the carbs, with a connector line between the hoses, capped off the other port, and still only open one petcock, with no starvation problems at all. Most of my riding is done on freeways at speeds around 65-70. Sometimes cruising at 80, and still no problem. Unless you ride at a very, very high speed, you should have no problems at all.
      • TonimusMaximus
        • 167
        • Phoenix, AZ
        What's wrong with your fuel tees?
        Tony K.
        TonimusMaximus
        Big Angry Scot - Clan Maxwell
        New 1978 XS11E Owner
        • CMA1
          • Jul 2003
          • 114
          • Ontario, Canada
          The plastic (poly) fuel "t"s can be purchased here....
          << http://www.crc2onlinecatalog.com/fuel_lines.htm >>
          that go in the fuel lines.
          Don't know about the "t"s between carbs at the fuel inlets.
          '79 Special
          • POOLBOY
            • Jan 2004
            • 64
            • ROCKFORD ILLINOIS
            Billet fuel tee's
            Try this address. They advertise Billet fuel tee's for gas or alcohol in the size you are looking for.
            www.pspmfg.com
            "BIG JOHNSON"
            1981 XS1100SH
            FINISHED,READY TO RIDE
            • sixtysix
              No XS but XSive as can be!
              • 1958
              • Central New York State
              Rob at www.motorcyclecarbs.com sells them specially made for the XS11 but they are pricey.
              Gary Granger
              • Duster
                • Jun 2003
                • 43
                • Central Texas
                Tony: I was using a long needle nose plyers to reconnect fuel line and poked a hole in the top of the T. I guess they get soft after awhile. I did have an extra from another bike but I was robing Peter to pay Paul. The ones from auto parts are longer (which can be cut) and the ID is allot smaller. Duster
                • nashville_bill
                  • 605
                  • Nashville, TN
                  Are you replacing the T's that are directly connected to the carbs, or the ones that connect the fuel line? If you are looking for the ones that connect the three fuel lines, 1/4" T's will work. If you are looking for the ones that connect the fuel lines to the carbs, look at www.motorcyclecarbs.com
                  Bill Murrin
                  Nashville, TN
                  2005 DL1000 V-Strom "WOW"
                  2005 FJR1300 Newest ride
