Jeremy, if you have the forks pulled out of the trees, you have half the work completed to change the fork seals. It is a simple process, and the seals are maybe $15 depending on shipping. So, I would recommend changing them now, it will REALLY suck if you get the bike all put back together and then you find you need new seals when oil is leaking.
Question about whether I have air forks or not.. hopefully an easy answer
78 XS750 -
Hey guys I got the caps off there and they ARE air forks but when I tried to bleed the air out nothing came out. The guy that had the bike before me was a complete idiot and I think he got this bike out of a field. The fork oil I drained (it started raining hard so I had to quit and cover her back up) was nasty looking and was probably the stock fork oil from 1979. I dunno if the forks will hold air yet but i hope so because I don't really want to change the fork seals anytime soon unless necessary.
working outside is not the best way.
I know that not everyone can bring the bike into the house but perhaps you could borrow the use of a shed?
That said, let me add to the recommendation that you change the fork seals now rather than later.
Also, a complete teardown & clean would be good. there's most likely 30 years worth of crud inside there.Fred Hill, S'toon
"The Flying Pumpkin"Comment
