valve clatter at startup
  • Justindrider
    • May 2011
    • 29
    • Dallas, TX.
    there is a ticking noise coming from the no4 cyl at startup but once it is warm it is fine is there somethiong wrong or am i just paranoid
    A bit of valve noise is actually a good thing. When the noise goes away, you need to adjust the valves again. When did you last re-shim the valves?
    • petejw
      • 2269
      • sydney australia
      also might want to check out that the exhaust
      is tight at the head and not leaking, also check
      ur spark plug is tightened up.
      pete
      new owner of
      08 gen2 hayabusa
      former owner
      1981 xs1100 RH (aus) (5N5)
      zrx carbs
      18mm float height
      145 main jets
      38 pilots
        • 9980
        +1 on what pete said. An exhaust leak will sometimes go away after things warm up. It will eventually get worse.
        • James England
          • 3039
          • North of England
          You don't want a loose spark plug... they chatter away the threads in the head. A 'ticking' can often be a tiny leak hissing rhymically
          • Justindrider
            • May 2011
            • 29
            • Dallas, TX.
            well its a used engine from a recycler, checked the spark plugs they are good and the exhaust checked out good im taking it this week to let them look over it so hopefully everything checks good
