update on my project
  • jwhughes3
    • 2798
    • Home of the Alamo
    George, just get some old gas and varnish up one hole in those pilot jets till they match
    If timing is same, Backfiring says lean to me, try to figure out why its lean.
    My $.02 and thats what its worth.
    John
    '81 XS1100H - "Enterprise"
    • GLoweVA
      • Jun 2011
      • 1957
      • Virginia Beach, VA.
      Too lean eh? I set the pilots out 3 turns. I know I have to sync but I'd like to get it idling better first.
      80G (Green paint(PO idea))
      The Green Monster
      Got him in '04.
      bald tire & borrowing parts
      Scarlet
      Got her in '11
      Ready for the twisties!
      81H (previously CPMaynard's)
      Hugo
      Cold weather ride
        But the poor idling can (and often is)cause by not having them synced. Do a sync then readjust things and then resync again.
        • GLoweVA
          • Jun 2011
          • 1957
          My poor scarlet has been patiently waiting for months.
          So, a few weeks ago, I did my shims in my G and in order to help that process along, I pulled all 8 shims out of my SG.
          Anyhow, just this Saturday, I got around to put my SG back together with the right shims.
          Since it had been sitting so long, I knew I had to pull the carbs and give them a once over again. Planned for Sunday.
          Sure enough, #3 carb had the jellies in it.
          I didn't use the right size flat head and I stripped the #4 pilot jet.
          Luckily, I found a small enough eazyout and it came out, but it was toast.
          So I pulled out my box of carb parts and saw those 4 shiny new pilot jets that came with those kits. I figured, what the heck, if I'm running a little lean anyway, then an extra hole in the pilot jet might help that out and I'm running a K&N filter so go for it.
          Got them put back together and back on the bike and put about a gallon of gas in the tank.
          Full choke and it started to come to life.
          After a min or 2, I came off the choke and she idled somewhat okay.
          I sprayed the pipes and #3 & 4 didn't sizzle like #1 & 2. ---- Fuel delivery issue on that side.
          Checked the bowl drains and #4 was minimal and #3 was almost dry.
          Had to put it on hold, football game started. (got to have priorities!)
          So, I've got to figure out if it's the petcock, the fuel T or both float valves. (I ditched the octy, so that's not it.)
          The Green Monster
          Got him in '04.
          Scarlet
          Got her in '11
          Hugo
          Cold weather ride
            Hey there George,
            Welcome back, was beginning to wonder where you were!?
            I doubt it's the petcocks, most likely the float valves, but also could be inline filters(remember the jelly) as well as inlet fuel "T"s, screen on bottom of float needle seat. You can test the petcocks just by pulling hose and turning ON, if they flow quickly/plentyful....there you go!
            Did you check those pilot jets for the location of their metering constriction? At the tip/pointy end is good, at the threads is bad.
            BTW, do I still have your OEM headlight lens??? Can't remember if you came by to get it swapped back out again??
            • GLoweVA
              • Jun 2011
              • 1957
              Hey TC. Been busy at work trying to get our Navy's newest submarine into the water.
              I still have your headlight, maybe sometime in the next few weeks I can swing by and swap them out.
              I didn't think to check the petcocks before putting the tank on the bike and putting fuel in it. Maybe this weekend/Friday, I'll pull the lines and see if they flow then, if those are okay, off with the carbs again.
              I'm planning on buying some tires this weekend for her and once they get in, maybe I can come by and we can put them on at your place.
              As for the pilot jets, they did have the metering hole at the tip, so they should work, just one extra hole. (you can see them here in the pic)
              The Green Monster
              Got him in '04.
              Scarlet
              Got her in '11
              Hugo
              Cold weather ride
                • 3189
                As far as I know those are incorrect for our carbs. The pilots should not have that many holes. There should be two and then one, for a total of 6 holes and not 8 in the pilots. I may be wrong and have been many times before but I am certain you have the wrong jets.
                  • 8794
                  Gotta watch out, the spray pattern on these jets will differ where they won't spray the fuel correctly. The 6 hole type will have the correct spray angle for our type of carbs.
                  07 Triumph Tiger 1050
                  • GLoweVA
                    • Jun 2011
                    • 1957
                    I know they're not the exact correct ones, but I didn't really have a choice at the time. The old one was stripped out and I needed to put something in the hole.
                    Phil: I'm just gonna try them out and see if they'll work. They were stamped 110 on the end, but comparing them to the old one, it's obvious they are not exactly the same.
                    I'll let everyone here know as soon as I can get the bike on the road if they seem to work or not.
                    The Green Monster
                    Got him in '04.
                    Scarlet
                    Got her in '11
                    Hugo
                    Cold weather ride
                    • CaptonZap
                      • Jun 2010
                      • 1748
                      • Denver
                      I wonder, if the side holes are the same size, one to the other, would it work to plug two of the holes on the new jets, and get a closer to original mixture out with the remaining six holes? JAT CZ
                      • GLoweVA
                        • Jun 2011
                        • 1957
                        Okay, so this morning I found that she has been leaking a little gas. I looks like it's coming from #3 carb, so this afternoon I got around to pulling the tank and the carbs off.
                        My left petcock barely leaks by on the prime port. (just a drop every few mins.)
                        Sure enough, #3 carb was flooded and it was leaking out thru the intake. After I got the carbs off, #3 intake boot was full of gas all the way up to the intake valve! (glad that particular valve was shut) No extra level in the oil, so no leakby past the intake valve.
                        So, My 2 new tires came in today, Maybe I can get TC to help me put them on.
                        This weekend it looks like the carbs are coming apart again to check the floats and valves and I might as well check the actual fuel heights too. While I'm at it, the petcocks are coming apart again to check them out too.
                        Oh, and I've got to wait for Nightengale to get his new clutch cable in, so I can get mine back. (it sure is nice to have friends local that can offer up parts when you're stranded on the side of the road. )
                        The Green Monster
                        Got him in '04.
                        Scarlet
                        Got her in '11
                        Hugo
                        Cold weather ride
                        • GLoweVA
                          • Jun 2011
                          • 1957
                          Picture!!!
                          Here's a pic of my Project: "Scarlet"
                          The red lettering on the tank and side covers is actually red sticky vinyl that the PO put over the letters and trimmed to fit. I think it looks pretty good and it matches the painted calipers and the frame cover near the neck.
                          The Green Monster
                          Got him in '04.
                          Scarlet
                          Got her in '11
                          Hugo
                          Cold weather ride
                            Looks nice!! I like the red also.
                            As to the VM style jets, hopefully you will have better luck with them. A while ago a member out of Indianapolis came on with issues trying to get an 80 Special running. He was ready to pitch the bike he was so tired of screwing with it, and SWMBO was ready to divorce him for spending so much time in the garage with it. I stopped by and took a look at his bike and carbs, sure enough he had the VM jets like you do. swapped out the jets and she purred like a kitten.
                            Good luck getting her going!!
                            • GLoweVA
                              • Jun 2011
                              • 1957
                              I don't think that they are VM style jets.
                              On mine, the metering orfice is at the tip end, like the BS ones in the pic.
                              They just have an extra air bleed hole. (8 instead of 6)
                              The Green Monster
                              Got him in '04.
                              Scarlet
                              Got her in '11
                              Hugo
                              Cold weather ride
                                • 3189
                                Just my 2 cents but then for sure I would not use them myself. You do what you will but I would not go to some jetting that is neither for our bikes or known (to us) bikes. They may fit the chainsaw TC has been talking about for all you know. they may also work great for all I know. Thing is for ten bucks give or take you get the right jets and we all breath easier knowing we are not answering questions that you knew the answer to going in.
