Idle trouble
  • Nubian
    • Apr 2011
    • 467
    • The Big East
    Idle trouble
    I did not synch the carbs yet, but I should still be able to regulate the rpm's right. After HE warms up, idles around 600, but jumps to 3K and keeps fluctuating while I ride. Never drops below 2K when riding. Now what?
    BAMN!
    '81 XS1100H "Brutus"
    That's a sync problem.... you won't be able to get a good idle until you do that.
    • Nubian
      • Apr 2011
      • 467
      • The Big East
      Help!
      Trying to synch carbs all 4 needles bouncing all over the place, metering valve does not seem to work,what am I doing wrong?
      BAMN!
        What type of sync setup are you using?
        • Nubian
          • Apr 2011
          • 467
          • The Big East
          3rd attempt at reply
          I am using a 4 gauge setup, one of the gauges is missing the dampening/metering knob. I am alternating to compensate. Also my readings are (using inside #'s of the dial) around the 50-75 marks all the other video's i've seen show the readings in the 200's.
          BAMN!
            The number readings are not important, the goal is to have them all the same. Try sticking an old pilot jet in the vac line of the guage for restriction to settle down the fluctuations.
            • petejw
              • 2269
              • sydney australia
              jat
              did u calibrate the guages before doing the sync?
              pete
              new owner of
              08 gen2 hayabusa
              former owner
              1981 xs1100 RH (aus) (5N5)
              zrx carbs
              18mm float height
              145 main jets
              38 pilots
              • Nubian
                • Apr 2011
                • 467
                • The Big East
                I know, I know hurrying as this will be my main form of transpo for awhile.I got it running ok for now, but thanks for reality check especially as beat up as the unit looks. Gonna test drive before it's too late, then I will do that.
                Originally posted by petejw
                jat
                BAMN!
