wires from the tank
  • Jelmo11
    • Nov 2011
    • 45
    • Sidney, Ohio
    wires from the tank
    Wires from my gastank ? What are the its a two connect clip what does it do?
    That is for the gas gauge sender on the standard or the low fuel light on the special.
      Fuel sender......special= light, standard = guage
      • Troney
        • Mar 2012
        • 48
        • Winnipeg, Manitoba, Canada
        Actually I have this issue as well. I have one that looks like it is just a slide on clip and one wire that looks like it is direct wired. Both are off the tank the direct wired is broken. on a 82 XJ1100.
        82 XJ1100
          yup. for some reason one wire is soldered on and the other is a spade connector. it is still the fuel level sender though.
          • Troney
            • Mar 2012
            • 48
            Right on thanks.
            82 XJ1100
            • SFerinTEXAS
              • Jun 2006
              • 877
              The XJ has the same 2 wire plug as the XS's in a 3 pin plug connector.
              79SF
              XJ11
              78E
              • SFerinTEXAS
                • Jun 2006
                • 877
                Just get some male/female connectors and your good.
                79SF
                XJ11
                78E
                • SFerinTEXAS
                  • Jun 2006
                  • 877
                  The wire that is soldered is the insulated connection to the internal
                  sender . Try to re-solder or replace the unit. NOTE. the XJ sender is not the same as a XS standard sender.
                  79SF
                  XJ11
                  78E
                  • mjpxs11sh
                    • Jan 2011
                    • 299
                    • N/E, Illinois
                    wire?
                    i would pull the gas tank and see if its connected to the sender. 2 wires?, i believe thats exactly where it goes.
                    Max
                    81 XS1100SH Black Beast Mutt
                    Kerker 4/1
                    stock carbs and air box.
                    78 headlite, handle bars,
                    1 set of ea-160/85mph guages,
                    crash bars, cruise control
                    Other 2 Wheelers
                    78 XS1100E jet kit, Kerker 4/1, air pods, jet kit-RIP
                    94 CBR1000F jet kit,Two Bros pipe, K&N Filter
