wtf is goin on ?????
  • Lbrown311
    • May 2011
    • 311
    • Minneapolis, Minn.
    Well I don't think you can disagree that it is far more accurate. The human eye is ment to be fooled. Use the bread tie
    1980 XS1100SG "Black Mamba" 28K
    1979 XS1100F 33k (Current Project)
    1981 XS1100H "Blue Balls" (Crashed and under repair )
    1978 XS1100E "Partsy"
    Work Hard, Play Harder!
    • cywelchjr
      XS-XJ Super Guru(Deceased)
      • 4450
      • Sacramento, CA
      Originally posted by skids
      The way I bench sych is to open the butterflys a little more than No. 3, turn the idle knob until No. 3 is barely letting light shine under it, and close the others to match. Use a flash light from the inlet side and look through the outlet side. This should get you pretty close for using the gages wen the carbs are reinstalled. I never liked the bread tie thing.
      The bench sync I use was from a field manual for my XS400 which said to use the idle ports and to set both the butterflies to cross the same idle port in the same place together. Adjusting that technique to the 4 XS11 carbs works just as well for our carbs and I feel is a little more accurate than the bread tie method and probably than the light method as well as you're using the measurement of greatest movement rather than least movement.
      • Hepcat
        • Apr 2004
        • 190
        • Captain Cook, HI
        When I had that problem, it was the throttle cable being clamped incorrectly. I'm 100 miles from my bike at the moment, so bear with me, but I believe there is an indentation on the metal at the carb end of the throttle cable. There is a matching bump on the metal clamp, make sure they meet. Mine was 1/4" further from the carbs than it should have been. I think the choke cable on my XJ is similar, but I don't think my XJ had a cable on the choke.
        YMMV,
        Jon
        __________________________
        Jon Groelz
        '82 XJ1100J-John
        '78 XS1100E-Name Forthcoming (It's a Girl!)
        • Jelmo11
          • Nov 2011
          • 45
          • Sidney, Ohio
          Ok just to make sure someone tell me what the small port on my number 2 carb not the boot the carb itself gets hooked too?? I know the one on my boot goes to the octy but what does the. One on the carb go to?
            • 3193
            Your vacuum advance on the timing side.
            • Jelmo11
              • Nov 2011
              • 45
              • Sidney, Ohio
              So it gets a line hooked to it that starts a little above the gear shift right?
                The port on the #2 carb body runs to the vacuum line that goes into behind the left side ignition cover. It is for your vacuum advance. Yes, it is in front and above of the shifter.
