After finishing the bearings and seals in the rear tire I went ahead and started on the front. I got the seals off and now I can NOT get the spacer moved over enough to hit the bearing, I get it moved over enough to hit the inside lip and slide off. I have tried hitting it with steel drifts to move it over but no dice on either side. Moved a tiny more on the r/h side but still not enough to hit the bearing.
Thanks in advance!
Thanks in advance!
