Some one please rescue me cant start my baby
  • DRedel
    • Mar 2012
    • 119
    • New York, N.Y.
    Hello all I just joined as a member. I have a 81 midnight special that I have been trying to get into fighting shape. After about a year of beg borrowing and stealing to get the bike started after years of sitting last fall I got her to run. I rode it for a few best weeks of my life. Then she died. The culprit was broken wires to the pick up coil. Fixed them and rode for a few more days and they broke again right at the coil so I had no wire to work with. She went away for the winter. Started a month ago and bought used pick up coils off eBay for 80 bucks. Ouch. Put them on and she won't fire. I the carbs keep back fireing out of the pod filters. I took of the timing plate to mess with the pick up so many times I'm afraid I might have spun the engine counter clockwise to get the bolt out. I'm also afraid that messing with it so many times the peice that the plate sits on which spins might have been loosened or screwed up some how. I have spark but it's just not hitting at the right time. Any suggestions help. Thanks Dustin
  • tcoop
    • Nov 2009
    • 793
    • South Weber, UT
    Is it possible that you have the wires to the coils bacwards?
    Ty
    78 XS1100E - Now in Minnesota
    80 XS1100LG - The Punisher
    82 XJ1100 - Daughter's Bike
      +1, Yep, I am betting your wires are backwards. As in, you put the coils in the wrong positions. Easy way to fix it, pull the tank off, pull the wires off the coils and swap them. Try to start it.
      • SFerinTEXAS
        • Jun 2006
        • 877
        Easy way to see if coils are wired wrong is to swap plug wires 1with 2 , 3with4.
        79SF
        XJ11
        78E
        • DRedel
          • Mar 2012
          • 119
          • New York, N.Y.
          I tried to swap the plugs but they won't reach I want to try to swap the coil wires do they just clip into the coils I just pull them out and reverse them or do I have to take the wires off one coil and but them on another thanks
          • SFerinTEXAS
            • Jun 2006
            • 877
            Maybe not be a possibility after all, went out to swap my XJ wires to see what would happen and the inner plug wires would not reach the outer plugs. My latent theory was that the wasted spark would run either way. May have the SF out later and will try it to see if they reach.
            79SF
            XJ11
            78E
            • DRedel
              • Mar 2012
              • 119
              • New York, N.Y.
              Do I need to do anything to get the timing right. Line up the arrow on the side to the timing plate or anything like that
                At the coils swap the wires. You will see one set has an orange wire with a red/white wire, the other set has grey with red/white. They probably match the wire colors of the coils. Swap the grey and red/white with the orange and red/white. The connectors are identical, so just un plug both, swap, and plug back in.
                  That's fixed and controlled electronicly.......
                    • 8962
                    It is possible to reinstall the reluctor 180 degrees out. IIRC it should be pointing at the top P/U coil when the engine is at #1 TDC. JAT
                      Originally posted by motoman
                      That's fixed and controlled electronically.......
                      But note that he replaced the pick-up coils... if he got an earlier assembly with slotted mounting holes, it might not be right...
                      • DRedel
                        • Mar 2012
                        • 119
                        • New York, N.Y.
                        I dident change the whole assembly I just took the pick up coils off and put ones from eBay on. How so I know If it's tdc
                          Pull the #1 (left side) spark plug, and the cover for the pick-up coils/timing. rotate the engine until the arrow and the "T" are ALMOST lined up. Put a "new" or long pencil into the spark plug hole, and SLOWLY rotate the crank. You should see the pencil rise and then stop. at that point, you are CLOSE to TDC, and the arrow should be lined up, or very close, to the "T" mark. If not, loosen the screws that hold down the plate the coils are mounted to, and rotate it one way or the other until you are on. Tighten the screws, and you should ready to ride. You WILL want to check with a timing light soon, if possible.
                          • CaptonZap
                            • Jun 2010
                            • 1748
                            • Denver
                            Not to worry, the plate will only go on one way, due to an offset slot in the plate hub. If you don't have to use a hammer to get the Allen bolt in, you're good. CZ
                            • DRedel
                              • Mar 2012
                              • 119
                              • New York, N.Y.
                              I have the tank off but I can't see the wires going into the coils to swap
