Does anyone have a schematic/diagram of the parts breakdown for the above title. My FSM only has it for the original E.
XS11H carb
The carbs are essentially identical; there's detail differences (floats, float valves, idle screws, etc) so while the parts may not look exactly the same, a given part is in the same place. The only thing I can think of that could trip you up is the idle screws. The '80-81 have those o-rings and washers that go on the end of the idle screw, otherwise everything else goes together the same.Fast, Cheap, Reliable... Pick any two
Yep, can't leave nuthin' alone... -
Look up the Tech Tip or thread titled Carb Cleaning 101. That set of pics and instructions is based on the 80-81 carbs.Life is what happens while your planning everything else!
78 XS750Comment
