WTF Exhaust Gaskets, are you too good for your home!?!
  • Joab
    • Aug 2010
    • 472
    • Ozark, Alabama
    Alright...so, I was putting the bike back together, and I go to put the exhaust gaskets in. Then put the exhaust on. Apparently, this sequence of events is just too much for me to handle, because it appears the exhaust will not go in with these freaking gaskets!
    This is all I pulled out of the exhaust ports when the exhaust came off.
    SO... now what??
    Joab
    "If nothing else, it will be interesting..."
    ______________________________________________
    1979 XS1100SF
    1972 XS2 650
    Ozark, Alabama
  • EricHa
    • Mar 2009
    • 201
    • IL
    The gasket in #1 looks farther recessed than the one in #3. Are you sure that there isn't an old gasket still in #3?
    Also, I would think that threading the exhaust studs in the head first would make the job much easier. I now defer to the XS gurus......
    1979 Yamaha XS1100SF (gone)
    Airbox w/K&N element
    Jardine 4 into 1
    145 mains, 45 pilots
    1996 Ducati 900SS CR
    1977 Kawasaki KZ900-A5
    1975 Honda CB550K
    • Joab
      • Aug 2010
      • 472
      • Ozark, Alabama
      Yeah, it isnt pressed in all the way. The issue I am having is the flange on the end of the header will not allow the header to go past the gasket. I am pretty sure if I force it, it will just tear up the gaskets, then they will just look like those remains on the ground, if I can even force it in at all.
      Joab
      1979 XS1100SF
      1972 XS2 650
      Ozark, Alabama
      • EricHa
        • Mar 2009
        • 201
        • IL
        The end of the header will meet flush with the gaskets, and the diamond flanges on each pipe will fit over the exhaust studs. Then tighten them down with the nuts. This will push the gaskets up into the head. Is this what you are wondering?
        Jardine 4 into 1
        1975 Honda CB550K
        • EricHa
          • Mar 2009
          • 201
          • IL
          OK, I may know what's going on. You need to have threaded studs sticking out of the head, like the ones in the pic below.....
          Do you have the studs to thread into the head?
          Jardine 4 into 1
          1975 Honda CB550K
          • Joab
            • Aug 2010
            • 472
            • Ozark, Alabama
            Maybe this exhaust isnt suppose to use gaskets? The flanges on the end of the header go deeper then the gaskets, pressed up against the gaskets, the diamond flanges wont even press up close enough to to tighten on the allen bolts.
            Joab
            1979 XS1100SF
            1972 XS2 650
            Ozark, Alabama
            • Joab
              • Aug 2010
              • 472
              • Ozark, Alabama
              No my exhaust was attached with allen head bolts.
              Joab
              1979 XS1100SF
              1972 XS2 650
              Ozark, Alabama
              • EricHa
                • Mar 2009
                • 201
                • IL
                All XS1100 exhausts use gaskets. Your exhaust is typical, nothing special. The flanges do not need to contact the head. In fact shouldn't I believe. Heading out, but others will be here.
                Jardine 4 into 1
                1975 Honda CB550K
                  The header seats up against the gasket, it does not go past the gasket.
                  The gasket gets sandwiched between the exhaust flange lip and the exhaust port.
                    Looks to me like there's 2 gaskets in the #3 port.
                    • Joab
                      • Aug 2010
                      • 472
                      • Ozark, Alabama
                      Alright, I think I see where I was getting confused. I was thinking the diamond flanges had to be flush against their mounting holes for the allen bolts, and that simply cannot be for the gaskets to rest properly against the header flange. Going back out to the garage to either mount it up or throw a motorcycle through a wall.
                      Joab
                      1979 XS1100SF
                      1972 XS2 650
                      Ozark, Alabama
                        You definitely want studs and nuts on these, not bolts. Using bolts, you'll run a pretty good risk of tearing the threads out of the head....
                        • Joab
                          • Aug 2010
                          • 472
                          • Ozark, Alabama
                          Yeah, you and EricHA are right on that count Steve. These allen bolts are a pain, but thats what came on the bike, I didnt know any used studs...I will go out and look for some this weekend.
                          Joab
                          1979 XS1100SF
                          1972 XS2 650
                          Ozark, Alabama
                            I have a 4-1 header that used one regular bolt (previous owner did that) and I believe all the others had allen nuts on the header studs. This makes an open wrench have descent access where the head pipe covers the end of where a stud would be. I liked it, so I am still using it.
                              PS, you just want to seal the head pipes with the crush gaskets. There is not need to torque the heck out of it! Also, I use "never Sieze" on the bolt. I hope it doesn't cook into something like glue...
