Starter still spins under 40 degree F
  • Snow
    • Oct 2002
    • 1041
    • Tallahassee, FL
    Hi All,
    I posted a little while ago that during the winter, my starter clutch would seem to disengage when under about 50 or 60 degrees F and that switching from 20w50 to 10w40 and adding some seafoam seemed to fix it.
    Well, now the temperature is dipping down into the 30's and 20's in the morning here. Once the magic number of about 38 degrees rolls around, that darn starter clutch starts a'slippin' again.
    There were some easy alternatives listed that one could do that do *not* require splitting of the cases... such as draining the oil and putting kerosene in the motor, then running unloaded on centerstand (if I remember correctly).
    Any other thoughts?
  • jkorn
    • May 2003
    • 179
    • Wickenburg AZ
    How about leaving it in the garage...
    That is a bit cool for me these days...
    jeff
    Jeff Korn
    Original Owner 79XS1100 E
    • Snow
      • Oct 2002
      • 1041
      • Tallahassee, FL
      Believe me, I would if I could - I'm currently trying to clear some credit card debt so that I might be able to mortage a house with garage and get out of the apartment complex.
      Heh heh, I can see it now, tucking my bike in the garage with blankets and love every night
      • mitch
        • Oct 2002
        • 934
        Just a thought
        In Canada the auto stores have a magnetic block heater you can buy. If you put one of those on your starter ( i think the case is metal ) and pluged it in i bet the heat would cure your prob !! Might be hard to find one in Florida but its worth a shot HTH......MITCH
        Doug Mitchell
        82 XJ1100 sold
        2007 Stratoliner 1900 sold
        • Snow
          • Oct 2002
          • 1041
          • Tallahassee, FL
          Might be just a tad hard to find, it's almost impossible to find ice-scrapers down here.
          • mitch
            • Oct 2002
            • 934
            PS :
            I think your name is a bit ironic seeing your living in florida lol....MITCH
            Doug Mitchell
            82 XJ1100 sold
            • Snow
              • Oct 2002
              • 1041
              • Tallahassee, FL
              Perhaps a little clarification will shed some light - I'm originally from the Winter Wonderland, born in and raised near Kalamazoo. Some of my fondest memories revolve around my brother riding his dirtbike in the snow with me on my metal sled being towed behind...I almost ate tree a few times as the rope was a bit long and the speeds a little too high.
              • mitch
                • Oct 2002
                • 934
                Block heaters
                They are just a heating coil in reality go to an auto place and buy a block heater for a Saturn SL1 they are made to go on the outsde of the engine and lay against the block ! Make a bracket to hold it to your engine on the bike so it will heat your oil. Problem solved......MITCH
                Doug Mitchell
                82 XJ1100 sold
                  Block heater
                  Growing up in Maine, (burrrrrr) I remember an oil heater that you could insert through the dipstick tube. You could fabricate some kind of plug for the oil fill port on the engine and insert the heater into the oil itself. You did say that when the engine warms up , you no longer have the problem, right? Maybe warm oil would be the answer.
                  • Garry W.
                    • Mar 2003
                    • 10
                    • Brandon Manitoba, Canada
                    So you call that winter!!!
                    Hey snow you should be so lucky that your starter spins at 40 deegres F. My xs is tucked in the garage nice and warm. Today is a beautiful day here in Manitoba,it's 10 below F. One week ago today it was Minus 38 degrees F. I garuntee you starter would'nt spin at all that day.
                    All kidding aside. Try taking your starter off and cleaning the shaft that the starter drive gear slides on and lub it with some light oil. I did that with my son's pickup truck and it seemed to help.
                    Enjoy your riding we,ve got at least another 3 months before we get out on the rode.
                    Garry W.
                      Starter gear
                      Garry, the starter on the bike is different than that on an automotive engine. The drive gear does not slide back and forth, but stays put, and is always engaged. It is driven by an overriding clutch, that is housed within the cranckcase. The starter on the truck has the overriding clutch built into the drive or "Bendix' as some folks call it.
                      • Garry W.
                        • Mar 2003
                        • 10
                        John your right. I should have remebered that. It's been a while since I've had the starter off my bike. Thanks and happy trails.
                        Garry W.
                        • TonimusMaximus
                          • 167
                          • Phoenix, AZ
                          I work at Checker Auto out her in AZ. I'll see if I can get you a ballpark price for that block heater, both the one for tyhe SL1 and one for say a SB Chevy. I'll let ya know.
                          Tony K.
                          TonimusMaximus
                          Big Angry Scot - Clan Maxwell
                          New 1978 XS11E Owner
                          • mitch
                            • Oct 2002
                            • 934
                            Saturn
                            The saturn one has a bracket to mount it all u need to do is find a bolt u can use in the right spot . A saturn SL1 1992 to 1999 will work HTH.......MITCH
                            Doug Mitchell
                            82 XJ1100 sold
                            • D. P. Larmee
                              • May 2003
                              • 224
                              • Evanston, IL
                              This might not be very useful now that the weather has finally warmed up a bit but I've had this same problem and found an easy fix. I have found that a 100 watt lightbulb on a lamp timer works great as a makeshift engine block heater. I usually set the timer to turn on a few hours before I need to leave and have had good results on all but the most brutally cold days. It seems to work even better with the bike cover on to hold in the heat
                              1980 XS 1100 Standard
                              1980 XS 1100 Special
                              1982 XJ 1100
                              1972 Honda CB 350
