Voltage issues
  • tweeleft
    • May 2009
    • 110
    • Bend Oregon
    Voltage issues
    Questions about voltage across the battery. At idle meter reads 13.9. I have a tach wobble at 2 to 4k. Rev motor meter goes to 15+ volts. No voltage change turning signals or hi beams on at idle. She does not run out good when riding. I've been though timing,sync carbs,air cleaner,auto cam chain tensoiner . She's a 79 SF
    Keep the shiny side up
    1979 XS1100SF
    Mac 4-1
    Drilled airbox Uni filter
    Vmax bars
    Virago 1" shorter shocks
    30K miles
    http://i1228.photobucket.com/albums/...429_135845.jpg
    1981XS1100SH
    '80 G Forks and Triple Tree
    '80 G tank
    Mac Turnouts
    Virago 1" shorter rear shocks
    SH Headlight
    http://i1228.photobucket.com/albums/...psd6adaae1.jpg
    61 Wife
    83 Son
    86 Son
    89 Daughter
    What are you experiencing when riding?
    • ddragon63
      • Jan 2012
      • 1101
      • Ridgefield, WA
      Sounds like its over-charging to me... should only be a little above 14 when alternator is excited. Possible voltage regulator spiking.... I'm sure someone more knowledgeable than me can chime in here. If it was a car I would suspect the volt reg every time for overcharge.
      Don
      old:
      1989 kawi ex500
      1996 yzf-r6
      1999 yzf-r1
      2001 kawi zx-6r
      2000 Ducati 748
      2002 YZF-R1
      2005 V-Star 1100 Classic
        Sounds like your voltage regulator is TU.... It would appear to be giving full output at all times (not 'regulating'), as you should have about 13.1V at idle and around 14V at 2000+ rpm. There is a test procedure in the manual to check the regulator. You need to get that fixed, as it's very hard on the components and the battery.
          Yeah, the voltage seems a little high but that shouldn't make it not run well Don. That could just be the meter he's using.
          Is the meter your using analog or digital tw?
          • ddragon63
            • Jan 2012
            • 1101
            • Ridgefield, WA
            a Don's right about the Reg would have been ok with me Steve
            I would assume the high voltage is spiking the ignition system and causing it to run like doo doo....
            Don
            old:
            1989 kawi ex500
            1996 yzf-r6
            1999 yzf-r1
            2001 kawi zx-6r
            2000 Ducati 748
            2002 YZF-R1
              That voltage does sound a bit Xsive at idle, the charging system is lucky to generate above 12 volts at idle!! Geezer makes a Reg/Rect that uses stronger components and does provide a stronger charging signal at idle. Are you sure your voltmeter is reading correctly??
              The reg/rect may Not be seeing a clean voltage level due to corrosion and such, and so it may be activating/triggering the coil earlier to get the voltage up since it's possibly not seeing as much voltage as what may really be there,
              but again, the XS's charging system just can't make much power at idle speed anyways! The book/manual test states at least 2500 rpm is needed to reach max alt output!!
              Would still recommend cleaning the electrical contacts, the wires at the reg/rect housing, it's connection to the frame and such. Then retest the voltages. Perhaps get some new alkaline 1.5 volt batteries and put them in series to test the voltmeter!?
              • cywelchjr
                XS-XJ Super Guru(Deceased)
                • 4450
                • Sacramento, CA
                Now I don't know these ignition systems as well as Davinci/Randy, but some electronic ignition systems don't like the voltage to be high and don't work quite right when it is. I don't know if that's the case here, but with voltage that high there is the possibility of damaging components and that needs to be fixed before going any further, or at least making sure that the readings are accurate. You CAN get the voltage that high at idle if you short the grounded side of the field coil, so those numbers are possible and should be verified.
                • tweeleft
                  • May 2009
                  • 110
                  • Bend Oregon
                  My meter is digital set on dcv I have another one I'll try tomorrow. As far as running while riding, sputters when twisting quick until about 4500 r's after tach wobble, smooth at slow twist of the grip
                  1979 XS1100SF
                  Mac 4-1
                  Vmax bars
                  30K miles
                  1981XS1100SH
                  '80 G tank
                  Mac Turnouts
                  SH Headlight
                  61 Wife
                  83 Son
                  86 Son
                  89 Daughter
                    The tach problem may or may not be a symptom of the problem. It runs off alternator pulses so if there is an alternator problem it could be part of it.
                    Whenever anyone talks of a sputter the first thing that always comes to mind for me is pickup coils. I fought thet problem for quite a while with my XS before I accidentally stumbled on the PU coil wires making intermittent contact.
                    Have you cleaned or rebuilt the carbs?
                    • tweeleft
                      • May 2009
                      • 110
                      • Bend Oregon
                      I checked my meters they are .1 volts off from each other. I used the higher of the two to get the readings I got. I'll do more tomorrow. Check ohms reading by the book(manual) thx guys I'll post more tomorrow
                      1979 XS1100SF
                      Mac 4-1
                      Vmax bars
                      30K miles
                      1981XS1100SH
                      '80 G tank
                      Mac Turnouts
                      SH Headlight
                      61 Wife
                      83 Son
                      86 Son
                      89 Daughter
                        At idle, since your charging system would put out less volts than the battery, you should be reading about the same as the battery's charge. In fact you should see the voltage gradually drop if you hold the idle speed...
                        • tweeleft
                          • May 2009
                          • 110
                          • Bend Oregon
                          Hey Thanks Guys. I pulled the voltage regulator and tested it on and off the bike as per manual. The regulator side is shorted. the diodes are good. Has anyone used the Accell regulators, I found them for half the price of greezers (can't aford the $125) like to get his thou. Not sure even when I can aford the Accells
                          1979 XS1100SF
                          Mac 4-1
                          Vmax bars
                          30K miles
                          1981XS1100SH
                          '80 G tank
                          Mac Turnouts
                          SH Headlight
                          61 Wife
                          83 Son
                          86 Son
                          89 Daughter
                          • cywelchjr
                            • 4450
                            • Sacramento, CA
                            Shop around and take a chance on a used one. I put a used one on mine over two years ago and it still works like new. I found one for $15, don't know if you can find that good of a deal, but you might come close on a used unit. IIRC there IS a way to roll your own as well, but that might actually cost you more.
                            • Elevener
                              • 608
                              • small town in TEXAS
                              Check with Andreas for one
                              Trapped in time. Surrounded by evil. Low on gas.
                              1980 XS1100G 1179 kit, Tkat brace, progressive springs & shocks, jardine spaghetti, Mikes coils, Geezer's rectifier
