front brake master
  • Cuda 69
    • Jan 2012
    • 676
    • Greenwich N.Y.
    front brake master
    OK, here we go, so I bought new front brake master cylinder for my bike from Mike's. There is an adjustment screw, I think it's for the piston for the brake,any idea's? and how does the adjustment work? it has a nut lock on it so you can lock the adjustment in place. My original equiptment doesn't have an adjustment... I'm lost. and not to start another thread,,, I used the mity-vac to bleed the brakes and that thing was useless.(could be just me) Bled the brakes the old fashion way.was way easier for me. How far should the brake handle go in(EX. half way?) thanks all
    FOXS-XS11SG
    1980 XS11SG-sold
    1999 Vulcan classic-sold
    1982 XJ 650-sold
    Is the adjustment screw on the MC body, or on the lever? The lever should have the screw, and that presses directly onto the piston. That is the "free-play" adjustment. On mine, if I squeeze really hard, I can get the lever to go down almost exactly halfway to the grip.
    • Cuda 69
      • Jan 2012
      • 676
      • Greenwich N.Y.
      Thanks Catonic, thats what I thought,but I still can't seem to get free play. i'll keep working at it. And my lever goes about the same. Thanks for the help.John
      FOXS-XS11SG
      1980 XS11SG-sold
      1982 XJ 650-sold
      • Elevener
        • 608
        • small town in TEXAS
        I have mine backed off about 1/16 of an inch before it engages mc piston, works fine that way for me
        Trapped in time. Surrounded by evil. Low on gas.
        1980 XS1100G 1179 kit, Tkat brace, progressive springs & shocks, jardine spaghetti, Mikes coils, Geezer's rectifier
          That's about the same for me. Just back the screw out all the way, then screw it in until just before it touches the piston. Then clamp down the lock nut. You just want to be sure you have a LITTLE free-play so you're not applying brake pressure when you don't want to be.
          • DamnXj
            • Feb 2012
            • 2
            • Greenville, NC.
            Hiya, I have an 82 xj1100, does anyone know if any or if all the front brake master cylinders from mikes works on my bike?
            • Cuda 69
              • Jan 2012
              • 676
              • Greenwich N.Y.
              not all master cylinders work,has to be the one for duel front brakes,or 1 front and rear in your case.
              FOXS-XS11SG
              1980 XS11SG-sold
              1982 XJ 650-sold
                You need to match bore size for the best results; going smaller or larger will change the 'feel' of the brakes and you might have issues with lever travel.
                  • 3192
                  Just a note on what Cuda has said here: The rear master does both the front left and rear brake work. The front only does one side on the front. Mikes does have one IIRC that is only 1mm difference in size.
                  If DamnXJ is simply replacing the front master it only needs to work on one disc. If he is to modify to accept both fronts then he would need the dual model.
                  • WSL91
                    • Feb 2012
                    • 427
                    • Quad Cities, IL
                    I've got one going on ebay here a little later tonight. I converted my XJ to a dual front setup de-linked to the rear and the original working XJ M/C will be up for sale beginning at 6:00pm Pacific.
                    1970? Honda Z50... gone
                    1974? Yamaha 100 Enduro... gone
                    1974 Honda CB200... gone
                    1981 Yamaha Virago 750... gone
                    1993 Honda Shadow 1100... gone
                    2008 Honda VTX 1800F
                    1982 Yamaha XJ1100J w/850 final, Raptor ACCT
                    1979 Yamaha XS1100SF "Chewey" Raptor ACCT
                    http://www.johnsoldiron.com
                    • DamnXj
                      • Feb 2012
                      • 2
                      • Greenville, NC.
                      Thanks for the info! Ill try to figure out what my bore size is and compare to his selection, thanks once again!
