Dyna Coil Wires
  • Joab
    • Aug 2010
    • 472
    • Ozark, Alabama
    Dyna Coil Wires
    Hey, for anyone who is running these green monsters, what plug wires are you using, and where did you get them from? Just bought a set of coils...now I need the sparky hoses to make the engine go boom!
    Joab
    "If nothing else, it will be interesting..."
    ______________________________________________
    1979 XS1100SF
    1972 XS2 650
    Ozark, Alabama
    Any solid core spark plug wire will work. Plenty of online sources and color options. I got some once from a small engine repair place.
    • TADracer
      • 1417
      • Kenner, Louisiana USA
      I use 8.8mm ACCEL stainless wires. Work great and hold up well. Got them several yearsa go from Dennis Kirk.
      Mike Giroir
      79 XS-1100 Special
      • James England
        • 3039
        • North of England
        I've had Green Meanies in two bikes and I always use silicone leads with graphite cores.... no metal in them at all. The silicone sheathing is ultra flexible and the graphite core is very low resistance and makes for a very flexible lead.
        I used them in conjunction with iridium plugs, having removed and bypassed the resistors from normal HT caps (because iridium plugs have a resistor in them already). You get a whopping spark with that setup. I had one through my hand, body and earthing through both feet. A hell of a punch.
        • Joab
          • Aug 2010
          • 472
          • Ozark, Alabama
          You know what James? I will take your word for it, and try very hard not to duplicate that experiment What is the part number for the iridium plugs for this bike? I will have to check around and see who has the best pricing for the silicone and graphite jobs you mentioned.
          Joab
          1979 XS1100SF
          1972 XS2 650
          Ozark, Alabama
            Get shot with a taser once and see if it punches harder than the coils!
            Now how could we hook those up to the plugs
            • James England
              • 3039
              • North of England
              It's all on eBay. I did the XS1100 and Honda GL1000 the same way. I would suggest removing the internal resistor in the plug caps and putting a small nail in there (they're spring loaded) because the iridium plugs have one anyway.
                BPR6EIX is the cross from BP6ES. Both are NGK numbers.
