Air jets
  • airborneXS
    • Feb 2012
    • 338
    • Houston, TX.
    Air jets
    I got a new set of carbs, thanks to tv5150, but the air jets that came in it are 210's....my question is this...
    I was running 145 mains and 45 pilots, with the stock 180 air jets...i have 4-1 kerker, no baffle, and pod filters...i did find problems in the carbs, but i had very poor mpgs, like around 27mpg....thinking i was running too rich....im gonna try 142.5 mains, 45 pilots, and what should I do with the air jets, the 180's or the 210's?
    79 XS11 special "Loki" - homemade 4-2 exhaust, pod filters, rebuilt forks with progressive springs, tkat fork brace, progressive shocks, rebuilt all brakes and MC's, rebuilt carbs with #142.5 main and #42.5 pilot, a custom front and chin fairing, and a handmade set of saddlebags....
    09 YZF-R1 " Toothless"
    04 Buell XB12R "Butterfly"
    "I had a name at some point, a birth-name, but now everyone just calls me Wolf...."
    Wolf
    Moto Militia MC
    210's are what came stock in the '78 carbs. Either will work, just gotta tune things.
      • 9980
      Check again nate.....
        Yeah and no matter how many times you post that chart Greg it is still wrong!
        '78's came with 210's. In '79 they went to the 180's.
          • 9980
          Two different charts say the same thing Nate. Are they both wrong?
          Not trying to be an XSokieSPECIAL but where do you get your numbers.
            A chart scanned from a manual (the one here) and a chart typed out by someone probably copying it from the manual does not necessarily constitute 2 separate charts. Manuals do make mistakes.
            When I found 210's in my carbs and asked wtf was up (cause I had seen that chart) I was told by many people that the chart was wrong. Also since this comes up somewhat frequantly that new people that have '78's find the 210's and wonder the same thing I would again tend to agree that the chart is wrong.
              • 9980
              Those are two separate charts from two different continents.
              Please copy and past what you found. Inquiring minds want to know.
                • 3189
                Every manual I have accessed says the 180 is the correct number. While I may be wrong as I have been many times before the 180 number stands in all my books.
                  That would have been a thread from ages ago! I don't want to go through all those old thread trying to find that!
                  • airborneXS
                    • Feb 2012
                    • 338
                    • Houston, TX.
                    so keep the 180's or try the 210's?
                    Wolf
                    Moto Militia MC
                      • 3189
                      I would tune to the 180's myself. The whole Kerker with no baffles will negate any common knowledge. I had done the whole pod thing before. I had to go up at least one size on the idle/air. The pods will make the carbs harder but not impossible. Good luck.
                        • 9980
                        I would think 210s would be WAY too rich. 180s and 185s is all that I can see was ever run and the 185s were in the 80 81 models.
                          • 5062
                          I can tell you this, because I tried it. The later model cab's air jets are a different thread than the earlier carbs. If you force the wrong jet in, it can bugger the threads.
                          There was a guy on this list long ago that said air jet sizes have less to do with richness than the sizes of fuel jets. If I remember correctly, he said that if you go increase the air jet size by 10, it is like going down with one size on the fuel jet. I think most people don't mess with the air jets...
                            I've personally seen both sizes in the '78 carbs, so some did come with the 210 jets. Maybe that was a early-production thing, who knows...
                              • 9980
                              Now that I think about it skids, a larger air jet would lean it not not richen it. that makes sense.
