straight header
  • mjpxs11sh
    • Jan 2011
    • 299
    • N/E, Illinois
    straight header
    so now ive put the bike back together after lubing the driveshaft/wheel splines and i see how the zirc fitting doesnt get the grease anywhere near the spline, only around the outside of the housing bearing (cup). i used a butter knife and packed it with Coastal NLGI-2 grease with moly. there wasnt too much grease inside around the driveshaft spline, so im glad it took care of it, thanks to all who posted. it was extemely easy. so i had to remove my 4/1 Kirker pipe and before reinstalling it, i was thinking about taking it out without the muffler and make some noise. my question is, will i cause any problems just running the straight 4/1 cause of lack of back pressure? im not planning on leaving it off, but i want to hear it and ride it without being mufflered. will it run too lean, or will it be ok?
    what do ya think?
    Max
    81 XS1100SH Black Beast Mutt
    Kerker 4/1
    stock carbs and air box.
    78 headlite, handle bars,
    1 set of ea-160/85mph guages,
    crash bars, cruise control
    Other 2 Wheelers
    78 XS1100E jet kit, Kerker 4/1, air pods, jet kit-RIP
    94 CBR1000F jet kit,Two Bros pipe, K&N Filter
    • 8930
    I run my Kerker with no baffle most of the time, it makes no difference, runs great either way, I prefer the louder sound unless on a long trip. I run larger jets and a drilled airbox with K&N. Kerker makes 2 collector sizes on their 4-1's, I have the larger size, 2 1/2" IIRC.
    • ManagerMike
      • Mar 2010
      • 445
      • S.E. Michigan
      You may notice a slight reduction in low end torque due to a leaner fuel mixture, or maybe not notice it due to the increased volume from the open exhaust confusing the senses, but as a temporary experiment, it should cause no harm.
      If you do however like the results and want to stick with the open exhaust, some jetting changes should be considered.
      '78 E "Stormbringer"
        • 8930
        Kerker with no baffle, Click on video....
        • mjpxs11sh
          • Jan 2011
          • 299
          • N/E, Illinois
          Rumble
          hey Phil, that sounds great. i like the rumble. im talking about no muffler, just the 4/1 open where the muffler attatches, not just the baffle. if it wont cause an issue, ill do a test ride and see how it sounds.
          Max
          Kerker 4/1
          Other 2 Wheelers
