spline grease
  • mjpxs11sh
    • Jan 2011
    • 299
    • N/E, Illinois
    spline grease
    i just bought a new Bridgestone Spitfire RWL rear tire for my 81 Special, so ill b removing the rear wheel. while im at it i want to remove the final drive to grease the splines that these bikes dont get lubed by the zirc fitting grease. this will b a first and im lookin for any helpful hints and also what type of grease to use . ive just used a wheel bearing grease gun on the zirc as a maintenence thing, but have learned its ineffective. thanx
    Michael
    Max
    81 XS1100SH Black Beast Mutt
    Kerker 4/1
    stock carbs and air box.
    78 headlite, handle bars,
    1 set of ea-160/85mph guages,
    crash bars, cruise control
    Other 2 Wheelers
    78 XS1100E jet kit, Kerker 4/1, air pods, jet kit-RIP
    94 CBR1000F jet kit,Two Bros pipe, K&N Filter
    • 6760
    Best results would be to use a moly60 type grease...this is whats used on my ST1100 and it stays on the splines...but I dont believe you need to remove the final drive to grease the splines...they are right there once you remove the wheel.
    1980 XS650G Special-Two
    1993 Honda ST1100
      • 2072
      Drive Shaft Spline
      Here Ya Go
      Also lube the rear wheel to final drive splines as was stated.
        • 6760
        Originally posted by Schming
        Oh yeah,Thanks for that one...lern sumthun nu everday
        1993 Honda ST1100
        • ddragon63
          • Jan 2012
          • 1101
          • Ridgefield, WA
          Michael
          I use the black Moly Extreme pressure grease in everything. I've got a tube of it in the grease gun and a can of bearing packing grease. The only thing better is the Lucas Red and Tacky grease. but it can be hard to find. We've been using the black grease for as long as I can remember in our 4x4 and racing applications for u-joints, ball joints, and bearings. I also use it in the bearing buddies on my boat trailer. I has a long life span and does not wash out easily. my .02
          Don
          old:
          1989 kawi ex500
          1996 yzf-r6
          1999 yzf-r1
          2001 kawi zx-6r
          2000 Ducati 748
          2002 YZF-R1
          2005 V-Star 1100 Classic
          • mjpxs11sh
            • Jan 2011
            • 299
            • N/E, Illinois
            moly 60
            ok, i called and found Honda Moly 60 at the dealership, but its only a 3oz tube. how much do u think i need to pack in both the driveshaft spline and the rear wheel to final drive spline. guess u dont use it like wheel bearing grease. i dont have to drain the final drive oil i just changed, do i?
            Max
            Kerker 4/1
            Other 2 Wheelers
            • ddragon63
              • Jan 2012
              • 1101
              • Ridgefield, WA
              You can get black moly grease @ any auto parts store. I was very liberal with my final drive greasing. Not sure if there's a specific amount your suppose to use. I did mine like I was packing a slip shaft on a tractor attachment. Cleaned and Packed the female side of the connection with grease, cleaned the male side and shoved em back together.
              Don
              old:
              1989 kawi ex500
              1996 yzf-r6
              1999 yzf-r1
              2001 kawi zx-6r
              2000 Ducati 748
              2002 YZF-R1
              • mjpxs11sh
                • Jan 2011
                • 299
                • N/E, Illinois
                grease
                thanx Don. this Honda Moly 60 is like a paste. i didnt buy it yet, but ill need to buy something. is the black moly like a grease. Guys using the paste say u paint it on, which means its not packed. i recently saw a new member here who is rebuilding a bike he just got and had the driveline apart with pix of the driveshaft spline packed with grease, but i cant seem to find him.
                Max
                Kerker 4/1
                Other 2 Wheelers
                • ddragon63
                  • Jan 2012
                  • 1101
                  • Ridgefield, WA
                  it was probably mine
                  The black moly in a can is paste like. Like wheel bearing grease. they also make it in a liquid tube for grease gun. I buy it @ autozone the brand name is Coastal. Staylube makes it too. So any NAPA, Autozone, O'Rileys will have it
                  Don
                  old:
                  1989 kawi ex500
                  1996 yzf-r6
                  1999 yzf-r1
                  2001 kawi zx-6r
                  2000 Ducati 748
                  2002 YZF-R1
                  • DeanR
                    • Jan 2005
                    • 1487
                    • Finger Lakes NY
                    this Honda Moly 60 is like a paste. Guys using the paste say u paint it on, which means its not packed.
                    That is correct. Good stuff. One tube lasts a long time.
                    80 SG
                    81 SH in parts
                    99 ST1100
                    91 ST1100
                    • mjpxs11sh
                      • Jan 2011
                      • 299
                      • N/E, Illinois
                      moly 60
                      so, Moly 60 is all u need to use? no packing any other grease in there. im gettin confused by other forums ive been reading. someone said it doesnt provide ALL the lubrication needed. im not sure i want to leave it dry. i called around to AutoZone, O'Reillys nobody has Coastal Black Moly if thats the complete name i should just use what Yamaha specs, NLG1-2, of course it doesnt state what the percentage is of moly disulfide is in it. i just want it to be lubed correctly. im lost!!!!!!!!!!!!i need a straight answer on what has been used and how much. hopefully ill have answers for members when they need help and ive done it right
                      Max
                      Kerker 4/1
                      Other 2 Wheelers
                        • 8700
                        I just use any type of axle bearing grease, usually marine grade, and slather it in there every other rear tire change (15K) and have never had any problems. You really don't need to overfill it. The picture above is way more than I would use. YMMV
                        • mjpxs11sh
                          • Jan 2011
                          • 299
                          • N/E, Illinois
                          allright, thanx Phil. i guess the NGL1-2 is sufficient then. everybody does thier own thng, i just need to get there haha i still dont know how a pea sized amount of Moly 60 protects what took 1-2 Tbls of regular grease. hopefully it will make better sense after i have it apart. then ill buy whatever i think makes the most sense.
                          Max
                          Kerker 4/1
                          Other 2 Wheelers
                          • ddragon63
                            • Jan 2012
                            • 1101
                            • Ridgefield, WA
                            It only looks like a lot... I didn't stuff it full what you see is just surface. I didn't put
                            any grease on the other side (male side). The theory is that it will push most of it down the splines when connected. We greased slip shafts on farm implements this way for generations with great success. May not be the way everyone else does it but it hasn't fail me yet in any situation. Any extreme pressure moy grease will be black. Sorry I couldn't help you further. Sounds like your getting it figured out thou.
                            Don
                            old:
                            1989 kawi ex500
                            1996 yzf-r6
                            1999 yzf-r1
                            2001 kawi zx-6r
                            2000 Ducati 748
                            2002 YZF-R1
                            • clcorbin
                              • Jan 2010
                              • 495
                              • Albuquerque, NM
                              You have to be careful here. The standard "moly grease" sold at auto parts stores have a few percent molybdenum added to standard grease and it does help quite a bit. But the "moly grease" specified for the splines is much, much, MUCH higher concentration of molybdenum, like in the range of 60% or higher. Needless to say, the low % stuff is NOT the same as the high % stuff!
                              Having said that, there probably are some auto parts stores that actually HAVE high moly grease (usually in a tub or tube), I just haven't ever seen one and in fact had to order the correct grease when I went through the final drive on my XS.
                              -- Clint
