What's the best way to "adjust" valves with no clearance?
  • Filter
  • #16
    Originally posted by blue83ranger View Post
    Just off topic, besides the return spring on the throttle is there any special way to get the throttle to return to idle on it's own?
    Synchronize your carbs.
    • #17
      I did, that's not the problem. The throttle itself doesn't return all the way unless i twist the throttle backward.
      1983 Ford Ranger 302 4x4
      1983 XR500R
      2003 KLX125
      '73 XR75
      '77/'79 XL75
      '85 atc250sx
      '85 tecate
      '04 TRX450R
      '97 TRX300 4x4
      '88 Terrapro
      '87 TRX250X
      '80 JD spitfire (2)
      '86 TRX250-4sale
      '82 XV750-4sale
      '76 GL1000-4sale
      '84,'68,'67,and '65 mustangs
      • #18
        Lube the cable, make sure it's not pinched some where and that it's routed correctly. ( I had the same problem on one of my bikes)
        Ty
        78 XS1100E - Now in Minnesota
        80 XS1100LG - The Punisher
        82 XJ1100 - Daughter's Bike
        • #19
          The only time I've had that problem was when the cable wasn't lubed or the throttle tube was sticking on the bar. In either case you need to fix the problem, which means as was mentioned by others, lube the moving parts, starting with the cable and make sure there aren't any tight bends in it, that will make it bind.
          • #20
            I'll do that then. If i hold it wide open (not running) and let go of the throttle it closes fine but when i either close it slowly or barely open the throttle it doesn't close all the way. so I guess it should be an easy fix with the lube.
            1983 XR500R
            2003 KLX125
            '73 XR75
            '77/'79 XL75
            '85 atc250sx
            '85 tecate
            '04 TRX450R
            '97 TRX300 4x4
            '88 Terrapro
            '87 TRX250X
            '80 JD spitfire (2)
            '86 TRX250-4sale
            '82 XV750-4sale
            '76 GL1000-4sale
