I'd be speculating, but the PO might have used the loctite to 'seal' the idle mix screws in place. Once set, they usually aren't adjusted ever again.
If the PO had air leaking past the screw, or vibrations 'loosing' them up some, then I can see the purpose of using something like loctite to fix it.
The problem is that stuff will eventually get sucked down into the carbs
Maybe acetone might be a decent solvent to loosen up the loctite.
Good luck, at least you have an idea of what might be in there, now it's time to figure out how to get it out.
