CARBS ... ugh
    • 8798
    Don't know which brand carb cleaner you are using but some are stronger than others. I would get some Berrymans (it will burn your skin) spray carb cleaner, tilt the carbs so it can sit in the clogged ports overnight without running out. Then give it a go again with a wire and compressed air.
    Edit: Any major autoparts like Autozone has Berrymans products.
    • airborneXS
      • Feb 2012
      • 338
      • Houston, TX.
      thats the one ive been using....
      79 XS11 special "Loki" - homemade 4-2 exhaust, pod filters, rebuilt forks with progressive springs, tkat fork brace, progressive shocks, rebuilt all brakes and MC's, rebuilt carbs with #142.5 main and #42.5 pilot, a custom front and chin fairing, and a handmade set of saddlebags....
      09 YZF-R1 " Toothless"
      04 Buell XB12R "Butterfly"
      "I had a name at some point, a birth-name, but now everyone just calls me Wolf...."
      Wolf
      Moto Militia MC
      • airborneXS
        • Feb 2012
        • 338
        • Houston, TX.
        still cant get it....ugh...ive been letting it soak, keep trying wire, nothing...ive cleared out every other orifice and hole except for those damn ports....the ports behind the air jets are cleared, its the port behind the pilot jet...it appears that there are actually 2 ports inside there...one that goes to the air jet and one that goes in the opposite direction...both 4 and 2 are cleared on both ports behind the pilot jet, but both 1 and 3 are blocked on both sides....ugh...cant figure this out, as soon as i get those ports cleared i can put this back together...
        Wolf
        Moto Militia MC
          • 2083
          There's supposed to be a washer between the spring and the o-ring, otherwise when you turn the idle screw the spring will chew up the ring.
          Oops sorry, yes that is correct. I've had these apart so long CRS kicked in.
            • 2083
            Pine-Sol
            Originally posted by airborneXS
            is there any solution i can use to cut through the grime on the outside of the carb bells to shine them up some?
            Here's a link:
            http://www.advrider.com/forums/showthread.php?t=560117 Soak it in pine sol. It's cheap and works magic. If it doesn't work, you're only out a couple bucks. ?
            • airborneXS
              • Feb 2012
              • 338
              • Houston, TX.
              #36
              so i let them soak since last night, they look great, but those 2 pesky little passages in the carbs are still blocked, not sure whats in there, but damn i wish i had xray vision....
              Wolf
              Moto Militia MC
              • petejw
                • 2269
                • sydney australia
                #37
                you'l have to keep spraying with carb cleaner,
                and poking at it with some wire, hitting it with
                compressed air to try and break
                up what ever u have in there.
                pete
                new owner of
                08 gen2 hayabusa
                former owner
                1981 xs1100 RH (aus) (5N5)
                zrx carbs
                18mm float height
                145 main jets
                38 pilots
                • airborneXS
                  • Feb 2012
                  • 338
                  • Houston, TX.
                  #38
                  im starting to think i just need a new carb bank....
                  Wolf
                  Moto Militia MC
                    Yammy can aleive that..........if you got d-e-e-p pockets.........bout 8 Ben Franklins........already mounted on the rack. Who knows, another used set may have another 'can of worms'..........persistance and patience WILL overcome......
                    • petejw
                      • 2269
                      • sydney australia
                      #40
                      if u go to a hobby shop u can pick urself up
                      a set of tiny drill bits, they can be used to drill
                      out pilot/main jets, pick a bit that is smaller than the
                      port, u can screw the bit in and then use it as a ream
                      to clean the ports out, the ports at the back of the carb bell
                      are straight, hopefully thatl be enuff to clean it out,
                      ive got a pic of the jets but i cant seem to post atm.
                      pete
                      new owner of
                      08 gen2 hayabusa
                      former owner
                      zrx carbs
                      18mm float height
                      145 main jets
                      38 pilots
                      • petejw
                        • 2269
                        • sydney australia
                        #41
                        heres a pic of the bits,
                        itl work better than poking the port with wire.
                        pete
                        new owner of
                        08 gen2 hayabusa
                        former owner
                        zrx carbs
                        18mm float height
                        145 main jets
                        38 pilots
                        • mack
                          • 2411
                          • Ontario, Canada
                          #42
                          airborne
                          Not sure how you're making out on this but if you can push the wire through the air jet port 2 3/8 inches you've hit the 90 degree turn to the pilot tower. You'll have to perform a flanking manouver and attack fron the pilot side. It is a bitch as the tower tunnel goes down so far then brends to the left. No way to ream it but dropping a couple wire gauges may allow you to make the turn. Try pushing up the PSI on your compressor. Good luck man. I think I have a spare #3 body if you need it. Float posts are intact. Concentrat on the number 1 first.
                          mack
                          79 XS 1100 SF Special
                          HERMES
                          original owner
                          81 XS 1100 LH MNS
                          SPICA
                          78 XS 11E
                          IOTA
                          https://youtu.be/wB5Jfbp6SUc
                          https://youtu.be/RaI3WYHSuWA
                          Frankford, Ont, Canada
                          613-398-6186
                          • airborneXS
                            • Feb 2012
                            • 338
                            • Houston, TX.
                            #43
                            this is where my problem lies.....
                            II even read somewhere that you can soak it in lemon juice, so i cut open a lemon and poured juice into both of the problem pilot ports, used a small lighter torch to heat up the passageway, still nothing....argh!!!!!!!
                            Wolf
                            Moto Militia MC
                              • 9980
                              The port your pointing at with the screwdriver on the left should be easily accessed through where the air jet screws in. The one on the right if you separate that carb you'll see a small steel ball that is epoxied in the hole where it was drilled. If you heat the epoxy with a propane torch you should be able to remove the ball so you can get down into the port on over to the pilot tunnel.
                              Those are actually two legs of the same port only on different carbs. It's where the air comes from for the air bleed on the pilot jet
                              • airborneXS
                                • Feb 2012
                                • 338
                                • Houston, TX.
                                #45
                                i cant access the blockage from the air jet port because of the 90 degree bend, the block is on the pilot port side...
                                Wolf
                                Moto Militia MC
