front MC rebuild
  • redbone
    • Oct 2007
    • 244
    • Waynesboro pa
    front MC rebuild
    hi everyone, been a while since i've been on...anyway, i'll be draggin my 1980 special out of storage shortly. i know it will need a front mc rebuild. the one shown on mikesxs (part# 08-0204) says it will fit 1100's 79-81 but it doesn't say if that is for standard or specials. is there is difference?
    also has anyone ever used the whole mc assembly for an 1100 from mikes part#08-0265 which says::: Master Cylinder Assembly - 16mm bore. - Recommended for late dual disc Front
    brakes on 1977-84 XS650's or single front disc brake (1972-76 650's). Yamaha
    OEM type. Complete with brake lever, brake light switch, banjo bolt and washers.Mirror mount has Left Threads
    any info appreciated,
    thakns
    redbone
    testing 1-2-3
    1980 1100 mns
    The Mike's rebuild kit is correct for your master cylinder. (Special or standard)
    I haven't tried it, but I believe the master cylinder you're considering is correct as well.
    While you're at it, be sure to rebuild the calipers. 2G2-W0047-00-00 CALIPER SEAL KIT
      The kit will fit.
      The standard MC mount is fairly level with the reservoir and the special has an angled mount because of the buckhorn handlebars. That MC looks to be a level mount.
      • redbone
        • Oct 2007
        • 244
        • Waynesboro pa
        thanks guys, and yes the calipers will get rebuilt as well. they are already ripped apart.
        redbone
        testing 1-2-3
        1980 1100 mns
          Originally posted by BA80
          The kit will fit.
          You would want to ditch those wheel barrow bars anyway, right?
            HEY! I like the buckhorns. I personally found the standard bars uncomfortable. I've got some CB750 bars on my project bike we'll see how those are but I've got another set of buckhorns standing by.
              You are made for playing foosball with no pain...
                Caused some pain to the other teams back in the day.
