Hey Fellas,
I installed the Raptor cam chain tensioner this morning.... Simple effective swap. I couldn't get pictures while putting it in as my head barely fits between the forks and the engine trying to get my head, both hands, and my phone in there was a no go.
Here is a picture of the stock one and the raptor tensioner side by side as you can see not only is there no rubber pad on the Raptor CCT it is also A crap ton stronger as the body it ALOT thicker!
So here is what I did...
Took Timing cover off. inserted 6mm hex into end of timing plate and rotated engine clockwise untill it was on the "C" mark. Took the 2 bolts out that hold the factory CCT in place. Gave the CCT a little love tap to break the gasket seal.
Took the bolt and spring out of the back of the Raptor CCT (has a copper washer behind the bolt head... no more leaks!
). Cleaned old gasket material off both the CCT and engine surface. Applied Permatex Ultra Black RTV to engine surface.
Depressed the 1 way ratchet bar of the Raptor CCT and depressed the plunger into the body as far as it would go.
Attached Raptor CCT body to the engine with the 2 old bolts. Inserted spring and bolt in hole in body. as I pushed the spring and bolt into the body I heard the ratchet click a few times as it pushed out to the guide bar. Tightened Spring bolt into body with supplied copper washer.
Ta-DAH
all done. I rolled the engine over by hand a few times to verify nothing bound up. Once I was satisfied. I pull the choke and fired it up. Runs great!
BTW the spring pressure of the raptor CCT is pretty damn close to that of the factory spring in the manual CCT. I will say 1 thing. the plunger depth CAN go in alot more on the Raptor CCT than the stock CCT. NOW after dismantling the factory CCT to look @ the set screw marks and I can tell you that from Stock SET (33 years ago) to this moring the marks are within 1/4 of each other... which BTW at the end of this there is only another 1/4 of adjustment left available on the factory CCT. I'm just going to assume (because I can't verify my claim here) that this overall 1/2 +- of adjustment area is a set distance for max chain stretch. When the CCT has made it to its limit the chain will become obviously noisy and you will not be able to adjust it to go away. Thus requiring you to need to buy a new cam chain.
So I like the idea of the Auto CCT no matter which bike you rob one from. But I would wanna warn people that they are now in charge of checking their chain themselves as now the auto CCT will just continue to push the chain in.
My $.02 on it YMMV
you can search my threads and find a comprehensive cross reference list of different models that you can get an Auto CCT from that was posted by other Forum Brothers.
You can find Raptor CCT's on Ebay all day long for under $20
Hope this was helpful and thing I missed I sure you guys will let me know. Any questions will be answered best as possible
Don
). Cleaned old gasket material off both the CCT and engine surface. Applied Permatex Ultra Black RTV to engine surface. Depressed the 1 way ratchet bar of the Raptor CCT and depressed the plunger into the body as far as it would go.
Ta-DAH
all done. I rolled the engine over by hand a few times to verify nothing bound up. Once I was satisfied. I pull the choke and fired it up. Runs great! BTW the spring pressure of the raptor CCT is pretty damn close to that of the factory spring in the manual CCT. I will say 1 thing. the plunger depth CAN go in alot more on the Raptor CCT than the stock CCT. NOW after dismantling the factory CCT to look @ the set screw marks and I can tell you that from Stock SET (33 years ago) to this moring the marks are within 1/4 of each other... which BTW at the end of this there is only another 1/4 of adjustment left available on the factory CCT. I'm just going to assume (because I can't verify my claim here) that this overall 1/2 +- of adjustment area is a set distance for max chain stretch. When the CCT has made it to its limit the chain will become obviously noisy and you will not be able to adjust it to go away. Thus requiring you to need to buy a new cam chain.
My $.02 on it YMMV
Don
