77 LH Control to my 79???
  • EKphys
    • Nov 2011
    • 17
    • Mankato, MN
    Okay...need to replace the left hand control cause the high/low beam switch handle is broken.
    I've found one from a 77 xs750. Will it fit on my '79 xs11 special. Seems reasonable, but a good fit maters! Thanks!
    -EKPhys
    1979 xs11special
    New to me fall '11
    Cleaned carbs, cleaned up overall winter '12
    Vetter Windjammer IV to be mounted w radio
    Trunk box to be mounted
  • tom clisham
    • Sep 2010
    • 627
    • Northern Illinois
    Connectors?
    If it has the same connectors it'll probably work. But, if not, it'd be easier to just get the right one off Ebay. 78-79s all the same.
    Tom Clisham
    79SF 1 owner,8000 miles, restoring to completely original ( I hope) GONE TO FRANCE
    • tom clisham
      • Sep 2010
      • 627
      • Northern Illinois
      Page 2
      Just realized that I probly have 1. PM if the 77 part doesn't work out.
      Tom Clisham
        The 650's hand controls work, but have different connectors but that is an easy swap. Not sure about the 750's though.
        ฮผฮฟฮปแฝผฮฝ ฮปฮฑฮฒฮญ
          • 9980
          If you want new Mikes XS has THESE. You'll have to put your plug for the 1100 on it but it's the same otherwise.
          Everybody is a genius. But if you judge a fish by its ability to climb a tree, it will live its whole life believing that it is stupid.โ€
          โ€• Albert Einstein
          • EKphys
            • Nov 2011
            • 17
            • Mankato, MN
            Hazard sw?
            My current LH control doesn't have the hazard switch. If i get a control with the hazard switch, may I wire it in?
            I read another post related...but I'm not sure what applies here.
            Sounds like picking up the 79 1100 model is most wise. Though I am comfortable swapping out the connectors...
            1979 xs11special
            New to me fall '11
              • 9980
              It would require some complicated wiring to wire in the hazzard flasher. That or a wiring harness from an 80 or 81 special.
              โ€• Albert Einstein
                Originally posted by BA80
                It would require some complicated wiring to wire in the hazard flasher. That or a wiring harness from an 80 or 81 special.
                Greg, it's actually not that complicated. The handlebar switch takes care of all the lights, all you need to add is a fused powered wire to the needed 4-way flasher, then a wire from the flasher to the otherwise-extra wire on the handlebar switch. The powered wire should be ahead of the ignition switch so you don't need to leave the key behind. There'll be some monkey-motion making it look decent and doing a nice job of making the connections, but that's it...
                  • 9980
                  Except he is working with a 79. There won't be an extra wire.
                  โ€• Albert Einstein
                    This is what I was referring to...
                      I'll also note that one effect that would only apply to the '79 Special with it's single indicator light is the indicator won't flash with the hazards with the stock wiring; to get it to do so, you'd have to do the diode mod to the light.
                        -EKPhys
                        Hi Eric,
                        up to the 1980 switch with the 4-way on it, the XS650/750/850/1100
                        have the same switch, same as the one from MikesXS.
                        That is, the look and the innards are the same. The wiring colours and their placement in the multi-plug may be different but that's an easy fix.
                        • EKphys
                          • Nov 2011
                          • 17
                          • Mankato, MN
                          Need to add a flasher?
                          Thanks Crazy...
                          Can you clarify "the needed 4-way flasher"? Do I need to pick up a flasher unit for the 4 ways? Then, I presume...wire from unswitched 12v...to flasher...to extra wire on the harness of my later style switch. The newer one has 5 wires on its second plug where the original has 4 (as expected).
                          Any recommends on the plugs? I could hunt for a matching female plug to match the new part...or just pick up a generic 6 way (5 would do) plug pair. The generic option seems easier...but maybe that female plug is easier to get than I realize.
                          On a side note, I'll need to clean up the hazard switch...it's stuck at 'off' until I get a sec to pull it apart and clean it out.
                          Thoughts? Finally feels like spring here in MN!
                          -Eric
                          1979 xs11special
                          New to me fall '11
                            ....Can you clarify "the needed 4-way flasher"? Do I need to pick up a flasher unit for the 4 ways? Then, I presume...wire from unswitched 12v...to flasher...to extra wire on the harness of my later style switch. The newer one has 5 wires on its second plug where the original has 4 (as expected)...
                            You only need to add the 4-way flasher if you want to have hazard lights. The '78-79 bikes didn't have them (and lack the mount on the frame for it), so if you want to add them, get a 4-lamp flasher and follow the wiring directions you have and hang the flasher someplace.
                            If you don't want to bother, then don't do anything. Just leave the 4-way switch in the 'off' position and everything else will work normally.
                            • EKphys
                              • Nov 2011
                              • 17
                              • Mankato, MN
                              Flashers... !
                              Makes good sense. But I'd not need an additional set of lights for the 4 ways, correct? Just a place to mount the flasher itself?
                              Or will the added flasher (circuit to pulse the 12v) control the existing lights?
                              And...about to mount the Vetter Windjammer IV up front. Say...any guess what size the threaded holes in the frame are for the fairing mount?
                              1979 xs11special
                              New to me fall '11
