CARBS!!! Now what to do?
  • RJFort
    • Jan 2012
    • 92
    • Bristol, CT.
    Ok so I was taking my carbs apart and I get to take the top of the carbs off and the screws are frozen and the couple that I dared to try to remove shredded on the first try. Now they need to be tapped. I am afraid that the rest of the damn thing is going to be like this. Anyone have any suggestions as to what my next step should be please? Should I just have them done by the shop up the road, and do away with any headaches? I really want to learn how to do these however. I was looking at the break apart diagram in the manual and it was overwhelming. I am sure I can learn to do it, just need to figure out how to get them apart without destroying anymore screws. Also do you know where I can find replacement screws? or will any do? Not sure if they were proprietary to mikuni.
    Thanks, just confused and wondering how to proceed next
    Rich (Ringo)
    '79 XS11 Special
    '02 VTX1800C (I know not a Yama but still mine)
  • DAVINCI
    • Jan 2011
    • 1048
    • Cedar Mountain, NC
    If you're overwhelmed, farm it out. BUT, be prepared to pay top dollar for carbs that may be clean, but may not run on the bike. Final adjustments are AFTER they're installed. If you just hand them to the shop, they can't do final adjustments.
    • RJFort
      • Jan 2012
      • 92
      • Bristol, CT.
      gonna bring them down to the shop so I can just talk to the guy about what I should do. Still want to hear your expertise. Not getting it done by him just want to show him what I am talking about and maybe he can show me too. Now that I started want to feel like I am continuing to move forward.
      Rich (Ringo)
      '79 XS11 Special
      • RJFort
        • Jan 2012
        • 92
        • Bristol, CT.
        the picture is overwhelming. I want to learn them, so I am going to try to do it myself but looking for guidance.
        Rich (Ringo)
        '79 XS11 Special
        • DAVINCI
          • Jan 2011
          • 1048
          There's a post here by a lovely member named Wildkat, look it up. Everything you want to know about carb cleaning is there.
          • James England
            • 3039
            • North of England
            They actually aren't that overwhelming. Remember, it's really just ONE carb you're doing.....four times over. Do them one at a time, is my advice and don't split the bank of carbs off the angle iron that holds them together.
            Spray penetrating oil on all the screws and leave for a few hours. Then, when it comes to removing them, use the correct screwdriver bit (no electric tools here) and, once you feel the head move slightly, spray more penetrating oil on it and tighten it back up and leave for a while, then, on screws that seem to get harder as you unscrew them, always screw them back in a turn. It clears the crud from the threads. If a screw you're undoing feels like it's getting harder to undo, stop! Tighten, penetrating oil and then carry on.
            Always use correct screwdrivers on all components, especially the jets. Don't use the wrong size flat screwdriver on them. Keep firm pressure on anything you're unscrewing, in order to stop the screwdriver from slipping and chewing things up.
            Have a well-lit DESK that you can sit at, with the carbs on a towel. Have a small pot into which you can put the various bits you take off.
            Take care removing the float pin (which sits in alloy 'legs' in the carb body). Use wire cutters under the flattened end to start getting the pin moving.
            If you do one carb at a time, stay methodical, and don't panic, you'll find iut easier than you think
            • RJFort
              • Jan 2012
              • 92
              • Bristol, CT.
              thanks guys. Went to the motorcycle shop down the street and he loosened all teh screws with an impact screwdriver, the kind you hit with a hammer. All the screws came out without issue afterwards. (thinking of investing in one of those). I took everything all apart and stuff was stuck. Very gummed up. I will post pics in a few.
              Rich (Ringo)
              '79 XS11 Special
              • tom clisham
                • Sep 2010
                • 627
                • Northern Illinois
                vise grips
                I've never failed to get em out with penetrating oil & vise grips.
                When you get carbs that've been POd & no screwdriver will turn the screws, try vise grips ( not the cheap imitation). Then, get new screws.
                Tom Clisham
                Age is relative YOU WON"T GET OLD TIL YOU SELL THE BIKE
                _____________________________________________
                '78xs1100E ,all stock & original GONE TO WISCONSIN
                '80 SG Vetter fairing,hard bags,trunk,fork brace,
                stock headers with fishtail mufflers,black & beautiful GONE TO ARIZONA
                79SF lowered,jardine 4/2 exhaust,pod filters,drilled rotors,fork brace, bar hopper
                79SF 1 owner,8000 miles, restoring to completely original ( I hope) GONE TO FRANCE
                • RJFort
                  • Jan 2012
                  • 92
                  • Bristol, CT.
                  ok, here is where we are at the moment.
                  everything separated.
                  gunk in bowl
                  gunk...
                  bottom
                  front
                  top down of dirtiest carb
                  back, green gas that was left over too
                  Rich (Ringo)
                  '79 XS11 Special
                  • RJFort
                    • Jan 2012
                    • 92
                    • Bristol, CT.
                    they were pretty gunked up, so I don't think the pine sol will work on this application. need to continue to disassemble to go dip them.
                    Rich (Ringo)
                    '79 XS11 Special
                      Ultra-sonic using PineSol...........might be surprised...........
                      • Cobia
                        • Jul 2007
                        • 1587
                        • Palm Beach County, Fl
                        They look pretty nasty for sure.
                        But you have further teardown ahead. Remove and clean:
                        - floats, valves, and seats (be very careful with the float pin)
                        - main jets and emulsion tubes
                        - pilot jets
                        - the two jets on the air intake side on all of them
                        Now you're ready to clean
                        Buy yourself four cans of the spray carb cleaner at Walmart, that stuff will really clean the gunk off. Spray it in every circuit (hole) and make sure it comes out somewhere else, typically where it should .
                        You may want to wear rubber/nitrile gloves and eye protection, that stuff is nasty and burns the skin. I recommend a respirator as well.
                        Good luck, have fun.
                        1980G Standard, Restored
                        Kerker 4 - 1
                        850 Rear End Mod
                        Automatic CCT
                        1980GH Special, Restored
                        '82 XJ1100 (Sold)
                        • RJFort
                          • Jan 2012
                          • 92
                          • Bristol, CT.
                          yeah I was gonna further take them apart, but I had other stuff to take care of sadly. I was gonna soak them in the pine sol first to try to take some of the smell and some gunk off first. I am working in the basement of a condo. No garage sadly. The GF loves the smell of engines and tools, but it is way strong, lol. I saw an ultra sonic cleaner at harbor freight, you think that would work? work will continue tomorrow after work. Gonna soak them overnight in pine sol i think.
                          Thanks guys. very helpful.
                          Rich (Ringo)
                          '79 XS11 Special
                          • RJFort
                            • Jan 2012
                            • 92
                            • Bristol, CT.
                            oh, forgot to mention. The number 2 carb. The little pin under the float is stuck up. The other three bounce freely. number 2 is gummed up.
                            Rich (Ringo)
                            '79 XS11 Special
                            • Eastcoaster
                              • Jan 2012
                              • 513
                              • oceancity NJ
                              Jets
                              Just finished round three on mine thanks to all I am good Make sure you get the emulsion tubes out that was my bid mistake Also my pilots were stripped I got the smallest easy out and they came right out and I replaced with new pilots and needle valves Hang in there it gets easier this group will get you through anything
                              82 XJ1100J
                              81 Venturer
