Cam Chain Tensioner swap - New parts source?
  • CodyLane
    • Apr 2010
    • 35
    • Vista, CA
    I recently rebuilt the engine of my 78 XS11 and it seems that everything else wants to break now that the engine is fixed. One of those things was the Cam Chain Tensioner. It leaked quite a bit no matter what I did. Recently, the bottom half of it cracked.The bike went from having a runny nose to a bloody one.
    That crack ended up getting some JB Weld that held (most) of the oil in.
    A while back I was reading about tensioner swapouts. Seems some of the guys were swapping CCTs from Ventures and Visions. Since my tensioner was jacked up, I took a gamble and ordered an automatic tensioner from a Yamaha Raptor 660
    Has the same offset as the XS11 tensioner
    It's a spring loaded ratchet. It looks almost identical to the Vision tensioner.
    I got this thing off of Ebay for $9. Free shipping too. I figured for that little money, it was worth trying. Turns out, it worked pretty much perfectly.
    Here's what I did:
    1. Removed timing cover
    2. Turned engine clockwise with a hex key (6mm) until the "C" mark lined up with the pointer
    3. Removed the 2 hex bolts (5mm) from the cam chain tensioner
    4. Removed the cam chain tensioner and paper gasket from the engine
    5. Loosened and removed large bolt (19mm I think) and underlying spring from front of Yamaha Raptor auto tensioner.
    6. Depressed the ratchet arm on the tensioner and pushed the plunger all the way back in.
    The ratcheting arm is on the bottom left of the picture. Note the copper washer on the bolt. No more runny nose.
    7. Put the gasket on the body of the auto tensioner and inserted into engine. Secured the body of the tensioner with the 2 hex bolts from the old tensioner.
    8. Inserted the spring and bolt and tightened down.
    I just painted that engine yet it's so dirty already.
    You'll kind of hear the plunger ratchet into place before you even get the bolt screwed in. The body bolted on to my engine with hardly any resistance. I did use a rattlegun though. Not much wins a fight against one of those.
    Everything seems to be working fine. Looking forward to not hearing that slapping cam chain noise. It'll be interesting to see how the auto adjust works out. The only thing I'm worried about is forgetting to check on it. The plunger on the old tensioner probably had about and 1/8" until it was fully extended. I'm guessing it's almost time for a new cam chain. This new tensioner will extend much farther than the original one and has the potential to let my chain stretch too far. Guess I'll have to keep an eye on it.
    Seriously though, $9 auto cct, Yamaha Raptor
    80 XS11 "Bellatrix"- MAC 4-1, ZRX1200 carbs, Dynatek Coils, Raptor CCT
    Cool!!! Another choice!
      More choices are a good thing.
        The part about using the rattle gun to put the bolts in made me cringe though.
        • old_skool
          • Nov 2011
          • 554
          • Ohio
          will these work on a 79special?
          81 XS1100H
            All these 1100 engines are the same as far as the tensioner. Yes it will.
            • old_skool
              • Nov 2011
              • 554
              • Ohio
              Thanks!!!!
              81 XS1100H
              • CodyLane
                • Apr 2010
                • 35
                • Vista, CA
                Using a rattlegun is probably not the best idea. It makes taking off the covers so fast though! I think I'm just sick of hex keys.
                • Poprock
                  • Apr 2005
                  • 594
                  • Oregon Coast
                  Great tip, Cody. I just scored one too. thanks
                  • ddragon63
                    • Jan 2012
                    • 1101
                    • Ridgefield, WA
                    Just ordered mine.... thanks for the heads up. I read this after I posted a question of what models to get one from. Should have searched the forums first...
                    Gonna assume you got yours from Muff's Motorsport's on Ebay as he has about a dozen of them listed on there
                    Don
                    old:
                    1989 kawi ex500
                    1996 yzf-r6
                    1999 yzf-r1
                    2001 kawi zx-6r
                    2000 Ducati 748
                    2002 YZF-R1
                    2005 V-Star 1100 Classic
                    • CodyLane
                      • Apr 2010
                      • 35
                      • Vista, CA
                      Totally got it from Muffs.
                      • ddragon63
                        • Jan 2012
                        • 1101
                        • Ridgefield, WA
                        My auto Raptor tensioner should be here by this weekend. if I got time with the rest of the stuff I have planned I'll get it installed
                        Don
                        old:
                        1989 kawi ex500
                        1996 yzf-r6
                        1999 yzf-r1
                        2001 kawi zx-6r
                        2000 Ducati 748
                        2002 YZF-R1
                        • tcoop
                          • Nov 2009
                          • 793
                          • South Weber, UT
                          Got my Raptor tensioner and installed it yesterday. (Got it for $7.02 including shipping ) it was a tight fit as far as the mounting holes but I didn't have to ream them. It probably would have gone on easier if I had reamed the holes a little. The spring tension seemed to be about the same as the venture ACCT.
                          Ty
                          78 XS1100E - Now in Minnesota
                          80 XS1100LG - The Punisher
                          82 XJ1100 - Daughter's Bike
                          • TomB
                            • 967
                            • Cumbria, UK
                            I've just had a bloke round here asking about his camchain tensioner on his Suzuki GSF600 Bandit, not sure if you lads get them over there, anyway he had it in his pocket for me to check out, its absolutely identical to the one in Cody Lanes pics below. That might open the possible parts cache.
                            Tom
                            • Poprock
                              • Apr 2005
                              • 594
                              • Oregon Coast
                              Got a Raptor tensioner from Muffs. Real fast shipping. Clean, slick part. Installed it yesterday with a home made rubber gasket. Glued it up with Honda HT gasket sealer. No road test yet, but it seems tight. Fit was perfect. Price was way right. Never did like the original. Cost me some intake valves when it failed.
