aftermarket gauges
  • raphael
    • Jul 2003
    • 13
    aftermarket gauges
    Hi
    Anyone installed aftermarket tach and speedo on a XS ?
    Is there any particular spec to look ?
    -speedo ratio...
    -tach compatibility with CDI...
    thanks for your help
    Raph
  • dragxs11
    • Jun 2003
    • 519
    • Reno, NV
    Hey Raph,
    I've looked into this a bit. I like the procycle guages made my autometer. They are expensive..... also I would have to mount a proximity switch on the front wheel as their speedo's are electronic. Not too difficult, but I decided to be satisfied with a used 160mph speedo and newer looking tach. It's fun to look though. I think the web address is www.autometer.com. If not, just do a google search. Thats gotta be close.
    Matt
    1980sg-Stocker-- Sold
    1980sg- Cruise Missile- Sold to RODS454
    1990 ATK 604- Ditch Digger
    2005 BMW K1200S- Killer Bee
    2005 Suzuki GSX-R 1000- trackbike
    • raphael
      • Jul 2003
      • 13
      Thanks for your reply
      I know these procycle instruments. The chrome white-face is nice-looking !! They're too expensive for me and can't find them on ebay, now I plan to mount mini tach and speedo.
      Did you meet any difficulties when wiring your tach ? where do you connect it on the CDI ?
      feel free to send me any pic of your gauges
      have a nice day
      Raph, France
      • dragxs11
        • Jun 2003
        • 519
        • Reno, NV
        Sorry, I should have clairified. I used stock guages, just from another bike. I'm gonna try putting blue or red lights in them so they look better at night, but I think thats as far as I'm gonna go. As far as wiring is concerned, I'm not quite sure. Normally you would tap a coil wire, but the question is how often does that coil fire. I know of newer bikes that fire every rev. and the piston position deturmines whether or not there is combustion, but not sure about xs's specifically. I think most aftermarket tachs here in the states are rigged of v-twins, so finding the right one would take some homework. Sorry I couldn't be more help.
          Hey there Raph,
          Unlike the OEM tach on our machines that is strangely wired with the alternator, most of the aftermarket tachs I've looked at all wire to the (-) side of the coils primary 12volt leads, not to the CDI persae!! The coils fire alternately, each one fires once with each revolution, providing spark to to cylinders, one on comp. stroke, one on exhaust stroke of the pair. I tried to find more info from some of the makers, but could only find general item info, not specific wiring or calibrating info!!??
          The Procycle gauges are quite pricey. There is a set in the JCW, black face, but are quite economical!! There are also some tachs shown in the Dennis Kirk catalog. They show an electronic tach by SHINDY that's white face, but it's listed on the SHINDY web site as Daytona gauge, and after a search, found that
          "Daytona Instruments" gauges is now owned by TCITECH or something like that. Good luck, most stuff you find seems to be for cruisers, with very high prices....all those Yuppies buying those wanna be Harley motorcycles!!
          • wildbill
            • Feb 2003
            • 346
            • western NC
            I have looked at gauges,about the only thing I can tell you is go to a auto parts store and browze some.I found a tach that might work,different sizes but no luck on a speedo yet.Have you checked JC Whitney?The shop on line is: www.jcwmotorcycle.com or aol keyword. jcw Hope this helps
            Bill Harvell
            • raphael
              • Jul 2003
              • 13
              Hi !
              I found some nice little gauges : http://www.highwayhawk.com/
              but can't say if the speedos would match. the question is ; what is the correct ratio ? ( some ahave 1:1 or 2:1 ratios....)
              thanks for your help guys
              Raph
              • wildbill
                • Feb 2003
                • 346
                • western NC
                There should be a phone number you can call,information.Dennis Kirk and J C Whitney have them.Pickup the phone and call.In the J C Whitney the decription for the tach is for all Yamahas.Just call.
                Bill Harvell
                • raphael
                  • Jul 2003
                  • 13
                  I live in Europe...and don't speak very well ; so a simple phone call becomes very expensive !
                  Many online vendors never answer tech question by mail ...
                  Raphael
                  • wildbill
                    • Feb 2003
                    • 346
                    • western NC
                    Raphael
                    I see your problem and may I make a suggestion.Does any of the shops,dealerships so forth,in other words ask them questions.Sounds a little strange but you won`t know unless you ask.There has to be somebody near you that could help. Good luck let us know
                    Bill Harvell
                      Hey there Raph,
                      Went to that web site, kinda pricey looking, mostly for Cruiser type bikes. I think what they're asking is whether for 1 turn of the front wheel, does the speedo cable shaft make only 1 complete rotation/turn, or does it take 2 turns of the front wheel for 1 rotation of the cable, etc.. I don't have mine apart, so I can't check, but perhaps someone else may know this, or you can take your Speedo cable out, block the front wheel up, and put something on one side of the cable so you can count how many times it rotates while you spin your front tire around once!?
                      I couldn't find much info on the Speedos on that web site!?
                      Hi !
                      Raph
