Oil level view window
  • XS1100 Newbie
    • Jun 2009
    • 1106
    • Battle Ground, Washington
    I looked the other day on here to see if anyone had a good way to clean the oil level window. Didn't see much other than pulling the cover. I didn't want to do that, so it was time to put my feeble mind to work. I drained my oil. Went to the handy dandy Ace hardware store, and go 2 foot of small engine fuel line that fit snug on the spray tube of my carb cleaner. I attached a length of wire to the tube, cut the length down, and taped the tube onto the spout. (just for safety, because the tubing fit snug) I then fed i down and into where the window is. Gave it a couple of squirts, and wow, it was crystal clear. Then i flushed about half a quart of trans. fluid i had down to wash it out. It evaporates fast anyway. I let it sit for an hour and a half, and the refilled with oil. Clean and easy. Maybe it will help someone out there.
    1980 XS1100LG Midnight
    1991 Honda CBR1000F Hurricane
    A cold beer and another one!
    Innovative idea!
      Okay XS11 Newbie,
      Where are the before and after photos, can't make a proper TECH TIP without some good photos!!!
        • 2104
        Good one Dude
        • barrelguy
          • 176
          • Oliver, BC
          And I JUST changed my oil! Anyway I'll give this a shop next go around. Thanks for the tip.
          1980 XS 1100 Special
          Mostly stock & original
          Added Yamaha fairing (w/ 8-track!)
          Torpedo bags
          New paint (still) pending
          Stainless brake lines
          Tkat forkbrace
          Coils from Honda 1000
          Previous bikes:
          1968(?) 350 Harley Davidson
          1977 Yamaha 650
          • XS1100 Newbie
            • Jun 2009
            • 1106
            TC: wasn't really thinking of a tech tip. Didn't take any pics. It probably won't get that dirty for another 30 years.
              Originally posted by XS1100 Newbie
              I looked the other day on here to see if anyone had a good way to clean the oil level window. - - -
              Hi Newbie,
              great idea but WTF, I can't see mine anyway because the sidecar gets in the way.
              I did use a mirror on a stick but people look at you oddly when you do that.
              Then I built a T-shaped dipstick to use when the engine is stopped.
              • cywelchjr
                XS-XJ Super Guru(Deceased)
                • 4450
                • Sacramento, CA
                That's a really good idea, but when I changed my engine and moved the clutch cover over to the new one, since it came without a clutch or the cover I went ahead and cleaned the window before I put the cover back on. It's still clean (on the inside at least, and I can clean the outside just fine with a rag) at this point, but I'll remember this technique.
