Hey XSives,
I got the old gal going, then discovered gas in the crankcase and changed out the oil, but didn't have a filter to replace the one in it that was saturated. Is this a problem in the short term?
Next, as it was running on idle fine for a few minutes after the oil change, it just stopped rather abruptly and wouldn't start. I checked and added more gas and still nothing. After pulling carbs for the 99th time (rechecked all floats 4 times in last 45 days) and pulling out the inline cone feul filters, still nothing. [BTW- am main jetted at 110 outside and 120 in, with 170 air pilot jets out and 185's in-make sense to you?]
Then, I pulled spark plugs and 1 & 4 were sooted up pretty badly (too rich?-see jetting?), but would not even spark when I grounded them. So, I checked coils (primary and secondary-both within spec), checked pickups all the way to black box- still good. By this time battery was pulled down a bunch and I set it up last night on a trickle. I am hoping a full charge will make a difference-but not so sure.
Any ideas? Am I missing something obvious, "plain as the nose on ma face", or what?
As usual, thanks for the 411, boys.
