Round Three?
  • Eastcoaster
    • Jan 2012
    • 508
    • oceancity NJ
    Round Three?
    XJ1100 did my second clean on the carbs I did not do a good job in the bowls on the starter feeds first round but now it starts great and runs well but when I go for a run anything over 3000rpm it bogs right down I replaced the pilot jets cleaned the mains set the floats replaced the needle valves and seats. It revs fine in neutral I just can't get it above 3000 on the ride I only cleaned the emulsion tubes in place I was not sure how to get out Can I replace them? Could the emulsions be causing the problem? I have been out of biking for 30 plus This awesome bike sat for 12 years It is in really good condition I just want to get this right I am just frustrated Thanks
    82 XJ1100J
    81 Venturer
    Originally posted by Eastcoaster
    ...I only cleaned the emulsion tubes in place I was not sure how to get out Can I replace them? Could the emulsions be causing the problem?
    If the carbs had any gum/crud in them, there's almost no doubt the emulsion tubes need cleaning too and that could be the problem. There's no need to replace them either unless they're damaged. To remove, pull the carbs, remove the bowls, main jets, and slide/diaphrams, then push the tubes into the slide hole until they drop out. Make sure you clean the holes out, and there's some small passages in there too. You can't get these carbs too clean....
    • XS1100_OEM4ME
      • Mar 2009
      • 1619
      • Fort Myers, Florida
      +1 on CS, just pull them (emulsion tubes) and clean the crap out of them Also, check and re-check ALL float hights Running out of fuel is most often a float hight thing, or a clogged gas cap vent thing or a pinched fuel line thing, you get the idea Make SURE nothing is slowing down the fuel flow
      1980 XS1100 Special
      1990 V Max
      1982 KZ750 LTD Twin
      1974 CB750-Four
      Past/pres Car's
        If it helps for directions, the main jet is what holds the emusion tubes in place. If they don't fall out easily, use a small wooden dowel and tap on the opening where the main jet screws into. That should knock the emulsion tubes lose. OFC, as Steve mentioned, the diaphragms need to be removed first, as that is where they will come out. Be careful when re-installing them, as there is a locating pin on the inside of the carb, and the groove on the side of the emulsion tube slides over that pin.
        • JeremyL
          • Jun 2011
          • 152
          • Oneida, TN
          My emulsion tubes were the cause of a lot of my carb problems so I removed them to clean them and 2 of them broke as got them out. I used a wooden dowel and carefully removed them but when I had them almost out and pulled on them with my fingers they just broke apart with hardly any pressure on them. The replacements I got (used) weren't brittle like mine were so yours may not be that bad.
          1979 Special with 1980 motor and 1979 carbs
          • Eastcoaster
            • Jan 2012
            • 508
            • oceancity NJ
            Thanks to all
            The information posted youall shared is great. I did not understand how they came out I am really new to all of this. I am confident I can do this. The service manual was very non descriptive and anything I googled had shown screwed in tubes I had no idea I was at a loss and cleaned as best I could.If they are anything like the others they are bad everything was clogged from a 12 year sit. I had to "easy out" the pilots to replace. I will start on the tear down toinght and let you know I can't thank you enough for pointing me in this direction I will post with the results as soon as I am back together
            82 XJ1100J
            81 Venturer
            • Eastcoaster
              • Jan 2012
              • 508
              • oceancity NJ
              Just a second thought? Compressed air?
              I was wondering if they are stuck is it possible to remove with compressed air?
              82 XJ1100J
              81 Venturer
                Nope, you'll have to push/gently drive them out...
                  Here is a thread you can go through on cleaning the carbs
                  • Eastcoaster
                    • Jan 2012
                    • 508
                    • oceancity NJ
                    Yikes what a mess Half way through
                    Its 2pm on the east coast I am half way through the emulsion tubes. So far the large opening near the area you thread in the main jet is full on all 4 tubes with soft gunk. In 2 the the small holes are non exsisting totally clogged the others had some blockage. In for the soak and clean now I will keep you informed Thank you to everyone for the help with this so far so good.
                    82 XJ1100J
                    81 Venturer
                      There's your problem. Be sure ALL THE PASSAGES are clean and flowing this round and you'll be in good shape.
                      • latexeses
                        • Jun 2008
                        • 1491
                        • California
                        I don't know if you ahve been warned about this before but be careful about soaking the carbs. If you use a carb dip it can ruin the rubber seals on the butterfly shafts.
                        Everything on hold...
                        • Eastcoaster
                          • Jan 2012
                          • 508
                          • oceancity NJ
                          Round 3 complete
                          Round 3 is in the books. I am down to under an hour on the install of the carbs It would have been a lot quicker if I had not mixed up the choke and throttle cables not to bright there seinor moment and my eyesite is not what it was. I still have a lot to learn and a lot to do. Upon the turn of the petcock fuel started to leak out the air box but a quick tap set the floats Whew. It fired right up and the throttle seems very responsive. I am anxious to get out on the road and try this we have ice and snow now so a hold on that for a day or 2. I hope this solves the problem Thank you to all with your help through this. l hope to report back with good news soon.
                          Eastcoaster
                          82 XJ1100J
                          81 Venturer
                            • 3193
                            Check out http://www.xs11.com/forum/showthread.php?t=35349 that will take your remove and install time way down. I can remove or install in under 5 mins now. Mind you I have had them off so many times I lost count, but this certainly helps.
                            Last edited by Rasputin; 02-12-2012, 06:27 PM. Reason: Fred will check on my spelling
                              XJ is a little tougher. I want a video of that 5 min time.
